NOT labelling certain features
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Fri Jan 19 07:38:39 EST 2007
Mike,
Try adding the following to your mapfile. You may have to tweak the
regex a little.
-Steve W.
Mike Saunt wrote:
> Hi All
> I've got a layer of roads where the description of various roads starts
> "REAR OF" or "ACCESS TO". I want to be able to label all roads that
> DON'T start with these terms as these are insignificant roads to label.
> I'm a bit unsure of the Filter / Expression to achieve this.
> Any help appreciated!
> LAYER
> NAME MinorRoads
> TYPE LINE
> STATUS DEFAULT
> CONNECTIONTYPE OGR
> CONNECTION "astun\MINORROADS.TAB"
> MAXSCALE 60000
> MINSCALE 10000
> LABELMAXSCALE 50000
> LABELITEM "DESCRIPTION"
> TRANSPARENCY ALPHA # so anti aliasing lines works
> CLASSITEM "DESCRIPTION"
CLASS
NAME "Noop"
EXPRESSION /^(REAR OF|ACCESS TO)/
# catch them here and do nothing with them
END
> CLASS
> NAME "Streets"
> STYLE
> COLOR 192 192 192
> SYMBOL 'continue'
> SIZE 5
> ANTIALIAS TRUE
> END
> STYLE
> COLOR 255 255 255
> SYMBOL 'continue'
> SIZE 3
> ANTIALIAS TRUE
> END
> LABEL
> FONT "arial"
> TYPE TRUETYPE
> ANTIALIAS TRUE
> COLOR 40 40 40
> OUTLINECOLOR 255 255 255
> SIZE 7
> POSITION AUTO
> PARTIALS FALSE
> BUFFER 4
> ANGLE AUTO
> END
> END
> END
> Cheers
> Mike
