Mapscript 4.10/Oracle Spatial : GetShape and drawQuery problems
Aude Allain aude.allain.ext at MAPPY.COM
Fri Jan 19 11:30:37 EST 2007
Hello,
GetFeature/GetShape :
I found the GetFeature function on this page : http://mapserver.gis.umn.edu/docs/reference/mapscript/index_html.
The tileindex of the objects are always equal at -1. So, when I call GetShape, the tileindex is always -1.
queryByAttributes/DrawQuery:
I don't understand when you say "the object did you selected is inside of
the actual extent of the map when you draw the map?" .
For me, the extent of the map which is displayed on the page has no link with my query. I just get the ID of the object to select in a text box, then I create a new mapobject, on which I execute the queryByAttributes function with the ID. Then, if I execute the drawquery function, the map extent must be automatically recalculated.
I tried to select the objects with an other field which contains 1 digit. I get the same result : the Image map is null but I have the selected objects the layer ($layer->getNumResults()).
If I use draw instead of drawquery, the image map is not null but all the geomteries are yellow, it's the HILITE color defined in the mapfile. It's strange, isn't it ?
But if I can't use fields with less than 14 digits because soon I will have ID of 17 digits...
Thanks of your help,
aude
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la part de Fernando Simon
Envoyé : vendredi 19 janvier 2007 02:04
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : Re: [UMN_MAPSERVER-USERS] Mapscript 4.10/Oracle Spatial : GetShape and drawQuery problems
Hi Aude,
    Sorry for the delay to reply your message. I'm out from the lab
and can't test here, I will go back to the lab just after the day 24
of January.
    About the error, the map (just draw from database) is working?
Another query function is working?
    I didn't found any reference to a GetFeature function the the
PHPMapscript reference
(http://mapserver.gis.umn.edu/docs/reference/phpmapscript-class/referencemanual-all-pages),
maybe the best way is the GetShape. Did you already tried with -1 as
tileindex parameter for getshape?
    About the question #2, the object did you selected is inside of
    Another thing that can be relate with the both problem is the size
of your ID column, can you try with a type that is small than 14
digits, like 5 digits? Some problems was reported between the size of
some columns and the shapeindex (the place where the UNIQUE will be
stored). Can you try with a column with less digits?
    When I go back to the lab I will test, I can't test here and look
more deep in the maporaclespatial code.
    Best regards from Brazil.
Fernando Simon
UMN Mapserver and Oracle Spatial developer
Citando Aude Allain <aude.allain.ext at MAPPY.COM>:
> Hello,
> Since I have installed the ms4w package, version 2.2.1, to have a
> compiled mapscript dll which supports oracle spatial, I have some
> problems with class methods.
> I use:
> -          ms4w : php/mapscript_4.10.dll, php 5.2, Apache 2.2
> -          Oracle Database 9.2
> -          Oracle Client 10g
> 1. GetFeature
> I have posted a message, without response to date, about the
> getFeature
> function. When I use it, I get the following error : Fatal error:
> Call
> to undefined function getFeature(). I use it because getShape() is
> deprecated. And if I get shapeObj with getShape function I always
> get a
> null object.
> My code :
>                         $layer              = $map->GetLayerByName
> ($tab_layers[$i]);
>                         $selectedObj   =
> @$layer->queryByPoint($geoClic,
> MS_MULTIPLE, 1);
>                         $nbSelectedObj          =
> $layer->getNumResults();
>                         if ($nbSelectedObj == 0)
>                                     continue ;
>                         $layer->open();
>                         $tabAttName = $layer->getItems();
>                         $nbAttL                     =
> count($tabAttName);
>                         for ( $j=0 ; $j<$nbSelectedObj ; $j++)
>                                    $object            =
> $layer->getResult ($j);
>                                    if ( $object  == null ) echo
> "<br>objet NULL ";
>                                    //$shapeObj     =
> $layer->getFeature($object->shapeindex);
> $layer->getShape($object->tileindex,$object->shapeindex);
> In each class of my mapfile, there is the line TEMPLATE
> "ttt_query.html".
> 2. queryByAttributes
> I call this function to get the object which has the 'ID' field and
> has
> the value '10400300001265'
> $res = $layer->queryByAttributes'ID', 'ID=10400300001265',
> MS_MULTIPLE);
> This call works, it permits to select the object in the layer
> because
> $layer->getNumResults() return 1.
> Then, I want to display the result so I execute the DrawQuery
> function
> on my map Object. And the returned imageObj is always null.
> Could you help me ?
> Aude
  Univali - Webmail - http://webmail.univali.br
