Query and Map reload
Eduardo Zenaide
ezenaide at GMAIL.COM
Fri Jan 19 13:06:26 EST 2007
Steve,
to be more especific, i'm using javascript to do queries. so i'm trying to
convert on variables some mapserver parameters to build the map based on the
query.
so far i have these:
var layer = document.pesquisa.layersList.value; //html comboBox to
select layer
var item = document.pesquisa.busca.value; //html input value
var operador = document.pesquisa.operadores.value; //another comboBox
for operators
and now the big problem. the next variable is based on html inputs i
generate through $gpoMap->extent->minx, for example. but it will return the
last map extension, not the one based on the query.
var minx = "minx=" + window.opener.document.myform.var_minx.value + "&";
so, what i want is how to know the extension (minx, miny...) from the query.
how to know the extension the query will return before the user submit?
thanks
Eduardo Zenaide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070119/22301194/attachment.html
