Help Setting up FCGI for Oracle Connection pooling
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Tue Jan 23 15:01:13 EST 2007
This is my first attempt to get FastCGI running with Mapserver to do
Oracle connection pooling, and it is not working. Any help would be
appreciated.
I have the mapfile working for CGI so I know I have the system and
environment set up correctly, but in fcgi mode I get:
This is the error message:
msDrawMap(): Image handling error. Failed to draw layer named
'Mexican_States'.
msOracleSpatialLayerOpen(): OracleSpatial error. Cannot create OCI
Handlers. Connection failure. Check the connection string. Error: .
This is the apache error.log:
[Tue Jan 23 12:44:48 2007] [warn] FastCGI: (dynamic) server
"/usr/lib/cgi-bin/mapserv410.fcgi" restarted (pid 15479)
[Tue Jan 23 12:44:48 2007] [error] [client 129.44.191.48] FastCGI:
server "/usr/lib/cgi-bin/mapserv410.fcgi" stderr: CGI Request 1 on
process 15469
server "/usr/lib/cgi-bin/mapserv410.fcgi" stderr: msDrawMap(): Layer 0
(color_symbol), 0.000s
"/usr/lib/cgi-bin/mapserv410.fcgi" (pid 15469) terminated by calling
exit with status '0'
LAYER
NAME "Mexican_States"
STATUS DEFAULT
TYPE POLYGON
CONNECTIONTYPE oraclespatial
CONNECTION "user/pass at test"
PROCESSING "CLOSE_CONNECTION=DEFER"
DATA "GEOMETRY FROM MEXSTATES USING SRID 4326 FILTER VERSION 10g"
##DATA "mdata/mexico/mexstates"
CLASS
NAME "Mexico States"
SYMBOL 0
COLOR 204 204 204
OUTLINECOLOR 128 128 128
END
END
Basically I have followed:
http://mapserver.gis.umn.edu/docs/howto/fastcgi
Running Debian Sarge
1) have the libfcgi-dev loaded
2) have the apache module loaded
3) build mapserver with fcgi support
swoodbridge at data:~/work$ "/usr/lib/cgi-bin/mapserv410.fcgi" -v
MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=FASTCGI INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS
INPUT=ORACLESPATIAL INPUT=SHAPEFILE DEBUG=MSDEBUG
4) have configured apache 1.3 thusly:
FastCgiConfig -initial-env PROJ_LIB=/usr/share/proj -initial-env
LD_LIBRARY_PATH=/home2/oracle/cl10/lib -initial-env
TNS_ADMIN=/home/swoodbridge/.oracle/ -initial-env
ORACLE_HOME=/home2/oracle/cl10/ -appConnTimeout 60 -idle-timeout 60
-init-start-delay 1 -minProcesses 2 -maxClassProcesses 20 -startDelay 5
LoadModule fastcgi_module /usr/lib/apache/1.3/mod_fastcgi.so
<Location ~ \.fcgi>
Options ExecCGI
SetHandler fastcgi-script
</Location>
5) installed mapserv as
cp mapserv /usr/lib/cgi-bin/mapserv410
cp mapserv /usr/lib/cgi-bin/mapserv410.fcgi
and have a shell script for CGI to set environment variables
swoodbridge at data:~/work$ cat /usr/lib/cgi-bin/mapserv410a
#!/bin/sh
export TNS_ADMIN=/home/swoodbridge/.oracle/
export ORACLE_HOME=/home2/oracle/cl10/
export LD_LIBRARY_PATH=/home2/oracle/cl10/lib/
/usr/lib/cgi-bin/mapserv410 $*
So this works in CGI mode but not fcgi mode:
# CGI
http://localhost/cgi-bin/mapserv410a?mode=map&layers=all&scale=50000000&map=/home/direct/mapserver/na_navteq_ora.map&mapxy=-75.7+45.42&map_size=300+200
# FCGI
http://localhost/cgi-bin/mapserv410.fcgi?mode=map&layers=all&scale=50000000&map=/home/direct/mapserver/na_navteq_ora.map&mapxy=-75.7+45.42&map_size=300+200
Anyone have some clue on this?
Thanks,
-Steve W.
