Help Setting up FCGI for Oracle Connection pooling
Fernando Simon fsimon at UNIVALI.BR
Wed Jan 24 06:22:23 EST 2007
Hi Stephen,
    This error (without error code, just point) that the Mapserver
reported occurs when the Oracle Spatial driver can't connect with
Oracle, when the Oracle variables are not present in the system
(ORACLE_HOME and/or ORACLE_BASE). Did you define it inside the
httpd.conf?
    Or, how you reported, the Mapserver can access the Oracle libs,
inside the path the ORACLE_HOME refer. How you report you can change
the permissions to the Ooracle director. The folders, just the
folders, need the execution permissions (+x). I don believe that the
Mapserver as FastCGI needs special access, here I use the PHP as
FastCGI and I didn't change any special about the Oracle.
    Another thing that I saw for FastCGI is the Oracle variables in
the Apache. When you define the Oracle Libs inside the httpd.conf the
FastCGI can't read correctly, you need to define the variables inside
the FastCGI module (the <IfModule fcgid_module>). Unfortunately I am
not in the Lab today (just tomorrow) to have access to my httpd.conf.
 I will send to you the configure that I use here tomorrow.
    Best regards.
Fernando Simon
UMN Mapserver and Oracle Spatial developer
Citando Stephen Woodbridge <woodbri at SWOODBRIDGE.COM>:
> Frank Warmerdam wrote:
> > Stephen Woodbridge wrote:
> >> Hi,
> >> This is my first attempt to get FastCGI running with Mapserver
> to do
> >> Oracle connection pooling, and it is not working. Any help would
> be
> >> appreciated.
> >> I have the mapfile working for CGI so I know I have the system
> and
> >> environment set up correctly, but in fcgi mode I get:
> >> This is the error message:
> >> msDrawMap(): Image handling error. Failed to draw layer named
> >> 'Mexican_States'.
> >> msOracleSpatialLayerOpen(): OracleSpatial error. Cannot create
> OCI
> >> Handlers. Connection failure. Check the connection string.
> Error: .
> > Steve,
> > It seems like you have done everything right.  Does the fastcgi
> > mapserver work for other stuff (like shapefiles) if there is no
> > oracle in the mix?
> > It looks like some sort of subtle environment type issue, but
> your
> > efforts seem pretty comprehensive.
> > Best regards,
> Hi Frank,
> Good call, I should have thought of that! Yes, if I change the
> mapfile
> to a shapefile only mapfile it runs just fine in fastcgi.
> Yesterday, when I was setting up the Oracle connection I got the
> same
> error message and resolved it by fixing the file permission on the
> /home2/oracle directory tree. So I guess there are still some
> issues
> there. I'll go back over that again maybe I missed something.
> Does the fastcgi version need access to different oracle client
> files
> that the CGI does not need?
> Thanks for the quick response,
>    -Steve W
  Univali - Webmail - http://webmail.univali.br
