Label with substring of metadata
Dylan Beaudette dylan.beaudette at GMAIL.COM
Thu Jan 25 14:28:26 EST 2007
On Wednesday 24 January 2007 20:57, David Isaacson wrote:
> Hi,
> I want to label my map with a substring of the metadata.  I've got a
> freeway map, and all of the freeways are labeled as "Interstate 5" and
> "US Highway 6".  I just want the number.
> Is this possible?
> I thought I might try to add that data to the .dbf file, using Excel.
> And it works using shp2img, but when I use ka-map to create an
> interactive map no roads are drawn at all (and no error messages are
> given either).  So what the hell is going on?
> What's the right way to add metadata to a shapefile (assume I can't
> afford to buy ArcGIS)?  And is there an easier way to do this whole
> labeling thing?  Thanks.
> David
Hi David - nice to see another UCD person using mapserver.
I would recommend looking into QGIS , uDIg, PostGIS, or GRASS as a means
to 'edit' a shapefile. It could be that excel saved a slightly incompatible
DBF version -- I have had this happen numerous times. Check column names and
their data type. If  you have the patience to try PostGIS -- it is possible
to do nearly anything with the spatial and attribute data imported from a
shapefile -- and you can pull the data directly into mapserver! We use this
setup here for all of our mapserver applications.
Cheers,
Dylan
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
