Label with substring of metadata
David Isaacson
david at CSE.UCDAVIS.EDU
Thu Jan 25 15:10:45 EST 2007
Thanks for your help, guys. It turns out (like usual) that the solution
was something simple. The permissions on the dbf file, which I copied
from Windows to Linux, were all messed up, and no one had read access.
I'll try one of those programs you mentioned next time I need to edit a
file -- excel was a pain.
David
Dylan Beaudette wrote:
>On Wednesday 24 January 2007 20:57, David Isaacson wrote:
>>Hi,
>>I want to label my map with a substring of the metadata. I've got a
>>freeway map, and all of the freeways are labeled as "Interstate 5" and
>>"US Highway 6". I just want the number.
>>Is this possible?
>>I thought I might try to add that data to the .dbf file, using Excel.
>>And it works using shp2img, but when I use ka-map to create an
>>interactive map no roads are drawn at all (and no error messages are
>>given either). So what the hell is going on?
>>What's the right way to add metadata to a shapefile (assume I can't
>>afford to buy ArcGIS)? And is there an easier way to do this whole
>>labeling thing? Thanks.
>>David
>Hi David - nice to see another UCD person using mapserver.
>I would recommend looking into QGIS , uDIg, PostGIS, or GRASS as a means
>to 'edit' a shapefile. It could be that excel saved a slightly incompatible
>DBF version -- I have had this happen numerous times. Check column names and
>their data type. If you have the patience to try PostGIS -- it is possible
>to do nearly anything with the spatial and attribute data imported from a
>shapefile -- and you can pull the data directly into mapserver! We use this
>setup here for all of our mapserver applications.
>Cheers,
>Dylan
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070125/cca435b2/attachment.html
