Does the current SDE driver in MapServer support logical and
regular expressio
Hong
ljfong at SDF.LONESTAR.ORG
Mon Jan 29 13:35:45 EST 2007
Thanks Andreas, it works now!
On Sat, Jan 27, 2007 at 09:44:55AM +0100, Andreas Albarello wrote:
> Hong wrote:
> >Then I guess I had the expression wrong then, here was the layer I had been
> >trying to display with multiple classifications:
> >LAYER # 9
> > NAME "Census Groups"[...]
> > CLASSITEM "POP2000"
> > CLASS
> > EXPRESSION "[POP2000] >= 0 AND [POP2000] <= 400"
> > STYLE
> > COLOR 112 247 38
> > END
> > END
> Hong,
> your expressions are syntactically correct, you only need to wrap them
> in brackets instead of quotes, so they are actually considered as
> expressions and not as strings.
> EXPRESSION ([POP2000] >= 0 AND [POP2000] <= 400)
> should therefore just work fine.
> Best regards,
> Andreas Albarello
> Analysis & SW Development
> Territorium Online srl/GmbH
> Via Buozzi/Buozzistra?e 12 - I 39100 Bolzano/Bozen
> email: andreas.albarello at territoriumonline.com
> web: www.territoriumonline.com
