problem with html legend + legend limiter?
Daniel Morissette dmorissette at MAPGEARS.COM
Tue Jan 30 13:28:16 EST 2007
Could you please try to view the HTML source of the page in which you do
not get any legend and see if any code is generated for the legend, if
you get truncated output, or what you get exactly?
I see that you do get a reference map below your empty legend which
makes me think that the problem may be different from the crash reported
in bug 1946... or at least the symptoms seem to be different. If you can
create a bug with a testcase to reproduce then that would help of course.
Daniel
Johan Van de Wauw wrote:
> Dear Mapserver users,
> I'm having some problems with Mapserver 4.10 and the html legend.
> I can generate an image legend for all my layers without any problems.
> Buthen I try to generate a html layer, this works for all my layers,
> except for one. This layer only works after I delete a lot of entries
> to make sure that there are only about 33 items in the legend.
> When I add that layer, my complete legend disappears, although I still
> have a correct map.
> Before adding the "evil layer": http://users.ugent.be/~jvdewauw/1.png
> After adding it: http://users.ugent.be/~jvdewauw/2.png
> (the templates used are the ones from the tutorials)
> Is this normal behaviour, or does any one have a clue what I'm doing
> wrong? I couldn't find any reference to similar problems. Is there a
> limit of items you can put in the legend?
> And now that I'm on the list anyway: the true reason that I'm trying
> to find out about this legend is that I would like to have some kind
> of a legend limiter, limiting the items in your legend to the items
> that are visible on the map. If someone has created or done an attempt
> to create something like that, I would really like to hear about it
> (my other map has >200 items) .
> Thanks already!
> Johan
Daniel Morissette
http://www.mapgears.com/
