PHP MapScript Wrappers for WxS Services
Maul, Andreas-Alexander Andreas-Alexander.Maul at BGR.DE
Wed Jan 31 05:45:19 EST 2007
Just after sending this mail I found the silly own mistake: the php script started with a newline in front of the opening php tag and ended with a newline after the closing php tag.
Stupid, stupid ...
Andreas
-----Ursprüngliche Nachricht-----
Von: Maul, Andreas-Alexander
Gesendet: Mittwoch, 31. Januar 2007 10:33
An: MAPSERVER-USERS at LISTS.UMN.EDU
Betreff: PHP MapScript Wrappers for WxS Services
currently we try to use the PHP MapScript wrappers for WMS services according to the PHP examples in the howto document http://mapserver.gis.umn.edu/docs/howto/wxs_mapscript.
Unfortunately we experience with the PHP mapscript functions ms_iogetstdoutbufferstring() or ms_iogetStdoutBufferBytes()
e.g. with
/*--------------------------------------------------*/ dl("php_mapscript_4.10.0.dll");
$request = ms_newowsrequestobj();
$request->loadparams();
/* Enable output buffer */
ms_ioinstallstdouttobuffer();
/* Create mapobject, execute request */
$oMap = ms_newMapobj("../mymap/wms.map");
$oMap->owsdispatch($request);
/* wich contenttype has been returned ? */
 $contenttype = ms_iostripstdoutbuffercontenttype();
 $ctt = explode("/",$contenttype);
/* Send response with appropriate header */
 if ($ctt[0] == 'image')
	header('Content-type: image/'. $ctt[1]);
	ms_iogetStdoutBufferBytes();
else
	header('Content-type: application/vnd.ogc.wms_xml');
ms_ioresethandlers();
that there is at least one additional blank line at the beginning of the sent document between http-header and binary data (i.e. the image) which seems to result in an unreadable file.
Environment: W2003 Server, IIS 6, PHP 5.2, MapScript 4.10.0 from MS4W 2.2.1 (maptools.org)
Does anybody know a workaround for this problem?
Regards,
Andreas
