System problems - installation
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Tue Jul 3 10:00:59 EDT 2007
I believe that MS4W version contains MapServer built with curl-7.15.1
with SSL enabled...but I have never gone as far as you and tried to use
the mod_ssl apache module, so you may be correct.
Please let the MS4W mailing list (join at
http://lists.maptools.org/mailman/listinfo/ms4w-users) know of your
progress, and if you include details instructions in your email to that
list I can make sure that the MS4W README is updated.
jeff
Crystal Li wrote:
> Hi all,
> I am new to mapserver, still have trouble with system installation.
> I tried differnt versions of MapServer, it seems there are some problems
> with SSL.
> Now I installed MS4W_2.2.3, Chameleon_ms4W-2.4.1-20060906,
> Apache_2.2.3-Openssl_0.9.8d-WIn32, I followed the instruction until
> postgresql is successfully installed. then I start apache again, there
> is error is
> below:
> The Apache service named reported the following error:
> >>> httpd.exe: Syntax error on line 114 of C:/ms4w/Apache/conf/httpd.conf:
> Cannot load C:/ms4w/Apache/modules/mod_ssl.so into server: The operating
> system cannot run The Apache service named.
> Please help! IS SSL version not matching Mapserver version? How can I
> fix this
> problem???
> not sure, tried to stop IIS and coldfusion services, still cannot start
> apache service.
> Thanks in advance!
> Crystal
> Crystal Li
> Systems Analyst
> Idisis, Inc.
> 430, 318 11th Avenue S.E.
> Calgary, Alberta T2G 0Y2
> www.idisis.com <http://www.idisis.com>
> E-mail: crystal.li at idisis.com <mailto:crystal.li at idisis.com>
> Office: (403)670-7351
> Fax: (403) 670-7359
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
