Mapscript and SOS
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Tue Jul 3 11:27:32 EDT 2007
Can you check your server logs see, exactly, what mapscript sends as the GetObservation request?
..Tom
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of "Peter Löwe"
> Sent: 03 July, 2007 11:12 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Mapscript and SOS
> Hi,
> the MapScript Wrappers for WxS Services indeed _do_ enable
> SOS requests, however, the results seem strange:
> A GetObservation-query like:
> http://localhost/swe/php_sos0.php?Request=GetObservation&servi
> ce=SOS&offering=oid_1&observedproperty=1234&procedure=sputnik0
> 01&version=0.0.31
> provides only the event time. (output follow below).
> Here's the SOS-relevant content which is provided via PHP:
> $oLayerSensor_temp->setMetaData("sos_procedure","sputnik001");
> $oLayerSensor_temp->setMetaData("sos_offering_id", "oid_1" );
> $oLayerSensor_temp->setMetaData("sos_observedproperty_id", "1234" );
> $oLayerSensor_temp->setMetaData("sos_describesensor_url",
> "139.255.165.155/swe/weatherstation.xml" );
> $oLayerSensor_temp->setMetaData("sos_componenturl",
> "139.255.165.155/swe/component.xml" );
> $oLayerSensor_temp->setMetaData("sos_observedproperty_name",
> "opid_name_Temperature" );
> $oLayerSensor_temp->setMetaData("sos_offering_description",
> "OfferingDescription_Temperature" );
> $oLayerSensor_temp->setMetaData("sos_offering_extent",
> "29.5.4, 34.5, 30.5, 35.5" );
> $oLayerSensor_temp->setMetaData("sos_offering_timeextent",
> "1982/2007" );
> This is the returned XML:
> <?xml version="1.0" encoding="ISO-8859-1"?>
> <om:ObservationCollection
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:ows="http://www.opengis.net/ows"
> xmlns:swe="http://www.opengis.net/swe"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:sos="http://www.opengis.net/sos"
> xmlns:om="http://www.opengis.net/om" gml:id="oid_1"
> xsi:schemaLocation="http://www.opengeospatial.net/om
> http://schemas.opengeospatial.net/om.xsd">
> <om:eventTime>
> <gml:TimePeriod xmlns:gml="http://www.opengis.net/gml">
> <gml:beginPosition
> xmlns:gml="http://www.opengis.net/gml">1982</gml:beginPosition>
> <gml:endPosition
> xmlns:gml="http://www.opengis.net/gml">2007</gml:endPosition>
> </gml:TimePeriod>
> </om:eventTime>
> </om:ObservationCollection>
> On the other hand, when the same amount of SOS-Metadata is
> provided through a map-file, the returned XMl is much more talkative:
> xmlns:om="http://www.opengis.net/om" gml:id="gauge01"
> <om:eventTime>
> <gml:beginPosition
> xmlns:gml="http://www.opengis.net/gml">2005</gml:beginPosition>
> <gml:endPosition
> xmlns:gml="http://www.opengis.net/gml">2006</gml:endPosition>
> </gml:TimePeriod>
> </om:eventTime>
> <om:member>
> <om:Observation>
> <om:procedure
> xlink:href="urn:ogc:def:procedure:SOSPROCEDURE_the_gauge"/>
> <observedProperty>ObservedProperty_the_gauge</observedProperty>
> <om:result>
> <gml:featureMember xmlns:gml="http://www.opengis.net/gml">
> <the_gauge>
> <gml:boundedBy xmlns:gml="http://www.opengis.net/gml">
> <gml:Envelope xmlns:gml="http://www.opengis.net/gml">
> <gml:lowerCorner srsName="epsg:4326">107.496
> -7.80619</gml:lowerCorner>
> <gml:upperCorner srsName="epsg:4326">107.496
> -7.80619</gml:upperCorner>
> </gml:Envelope>
> </gml:boundedBy>
> <msGeometry>
> <gml:Point
> xmlns:gml="http://www.opengis.net/gml" srsName="epsg:4326">
> <gml:coordinates
> xmlns:gml="http://www.opengis.net/gml">107.496,-7.80619</gml:c
> oordinates>
> </gml:Point>
> </msGeometry>
> </the_gauge>
> </gml:featureMember>
> </om:result>
> </om:Observation>
> </om:member>
> Any suggestions how to make the Mapscript-Wrapper version
> more verbose ?
> CU
> Peter
> >There is no direct support through the scripting languages
> to call SOS
> >requests or any other OGC specific requests.
> >You may want to look into the MapScript Wrappers for WxS Services
> >(http://mapserver.gis.umn.edu/docs/howto/wxs_mapscript) if
> that can be
> >used for you purpose.
> >Later,
> >Peter Loewe wrote:
> >> Hi,
> >> does any information exist how to formulate SOS
> getObeservation / describeSensor >>queries when using
> Mapscript/PHP in the backend ?
> Dr. Peter Löwe
> <peter.loewe at gmx.de>
> Psssst! Schon vom neuen GMX MultiMessenger gehört?
> Der kanns mit allen: http://www.gmx.net/de/go/multimessenger
