label with mapscript
joerg pfeiffer
superbla3000 at GMX.NET
Thu Jul 5 17:52:37 EDT 2007
Hey Pietro,
thanks for your help. It seems my mapscript version is not up to date,
so it doesn't know the ms_shapeObjFromWkt function. But I got it working
with the following code. Only problem: It only prints one label, not as
many labels, as I have in the array:
$LabelLayerObj = $this->map->getLayerByName($layername);
$labelpointObj = ms_newPointObj();
$labelLineObj = ms_newLineObj();
for ($i = 0; $i < count($pointlist); $i++){
$labelpointObj->setXY(100+($i*2),100+($i*2));
$labelLineObj ->add($labelpointObj);
$labelshp = ms_newShapeObj(MS_SHAPE_POINT);
$labelshp->set("text", $pointlist[$i] );
$labelshp->add($labelLineObj);
$LabelLayerObj->addFeature($labelshp);
So if I know how to print more than one label, I would be very happy! :-)
cheers
Joerg
pgiannini at bytewise.it schrieb:
> Hi Joerg,
> try:
> $oMap = ms_newMapObj("your.map");
> // obtain the layer object:
> $oLay = $oMap->getLayerByName("citylabels");
> // obtain a shape object with the fields of a form (in this case they are
> named 'X' and 'Y'):
> $oShape = ms_shapeObjFromWkt("POINT(".$_REQUEST['X']."
> ".$_REQUEST['Y'].")");
> // set the text property of the shape object:
> $oShape->set("text","ciao");
> // add the shape to the layer:
> $oLay->addFeature($oShape);
> // draw the map:
> $oImage = $oMap->draw();
> $mapImage_url = $oImage->saveWebImage();
> I tried and it works well.
> You can create how many features you want.
> Hope it is useful...
> ciao
> .............................pg
> Pietro Giannini
> Bytewise srl - Area GIS
> 41°50'38.58"N 12°29'13.39"E
>> Hello,
>> I have this simple layer:
>> LAYER
>> NAME "citylabels"
>> STATUS DEFAULT
>> TRANSFORM FALSE
>> TYPE ANNOTATION
>> FEATURE
>> POINTS
>> 200 150
>> END
>> TEXT 'Hello world. Mapserver rocks.'
>> END
>> CLASS
>> LABEL
>> TYPE BITMAP
>> COLOR 0 0 0
>> END
>> END
>> END
>> and would like to set the place and the text dynamically with
>> php-mapscript.
>> Does anybody have a simple codesnippet?
>> best regrads
>> Joerg
> Pietro Giannini
