Mapscript and SOS
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Fri Jul 6 13:45:13 EDT 2007
Kralidis,Tom [Burlington] wrote:
> Trying this with svn trunk gives me blanks for all responses for SOS. Yet WMS and WFS seem to work (for GetCapabilities).
> Using svn trunk, When testing a simple PHP Mapscript WxS:
> <?php
> dl("php_mapscript.so");
> $request = ms_newowsrequestobj();
> foreach ($_GET as $k=>$v) {
> $request->setParameter($k, $v);
> ms_ioinstallstdouttobuffer();
> $oMap = ms_newMapobj("/path/to/config.map");
> $oMap->owsdispatch($request);
> $contenttype = ms_iostripstdoutbuffercontenttype();
> $buffer = ms_iogetstdoutbufferstring();
> header('Content-type: text/xml');
> echo $buffer;
> ms_ioresethandlers();
> - issuing a WMS 1.1.1 GetCapabilities works as expected
> - issuing a WFS 1.0.0 GetCapabilities works as expected
> - issuing a SOS 0.1.2b GetCapabilities returns a blank
> Assefa: is there anything else in mapogcsos.c we have to do to make it mapscript WxS friendly?
Tom. I see the problem. Currently the sos output using something like
xmlDocDump(stdout, psDoc); and thus does not take advantage of the
ms_ioxxx functionalties. I am looking into how to modify this.
> ..Tom
>> -----Original Message-----
>> From: UMN MapServer Users List
>> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of
>> Sent: 03 July, 2007 11:51 AM
>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>> Subject: Re: [UMN_MAPSERVER-USERS] Mapscript and SOS
>> Weird. What happens (in terms of the response) when you do a
>> GetCapabilities via mapscript and regular SOS request? I
>> wonder if the metadata is actually being set.
>> ..Tom
>>> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of "Peter Löwe"
>>> Sent: 03 July, 2007 11:46 AM
>>> Hello Tom:
>>> After calling up
>>> http://localhost/swe/php_sos0.php?Request=GetObservation&servi
>>> ce=SOS&offering=oid_1&observedproperty=1234&procedure=sputnik0
>>> 01&version=0.0.31
>>> the apache access_log holds:
>>> ::1 - - [03/Jul/2007:17:36:37 +0200] "GET
>>> /swe/php_sos0.php?Request=GetObservation&service=SOS&offering=
>>> oid_1&observedproperty=1234&procedure=sputnik001&version=0.0.3
>>> 1 HTTP/1.1" 200 790
>>> and this piece of XML is returned:
>>> <?xml version="1.0" encoding="ISO-8859-1"?>
>> <om:ObservationCollection
>>> xmlns:gml="http://www.opengis.net/gml"
>>> xmlns:ows="http://www.opengis.net/ows"
>>> xmlns:swe="http://www.opengis.net/swe"
>>> xmlns:xlink="http://www.w3.org/1999/xlink"
>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>> xmlns:sos="http://www.opengis.net/sos"
>>> xmlns:om="http://www.opengis.net/om" gml:id="oid_1"
>>> xsi:schemaLocation="http://www.opengeospatial.net/om
>>> http://schemas.opengeospatial.net/om.xsd">
>>> <om:eventTime>
>>> <gml:TimePeriod xmlns:gml="http://www.opengis.net/gml">
>>> <gml:beginPosition
>>> xmlns:gml="http://www.opengis.net/gml">1982</gml:beginPosition>
>>> <gml:endPosition
>>> xmlns:gml="http://www.opengis.net/gml">2007</gml:endPosition>
>>> </gml:TimePeriod>
>>> </om:eventTime>
>>> </om:ObservationCollection>
>>> ..Peter
>>>> Can you check your server logs see, exactly, what mapscript
>>> sends as the >GetObservation request?
>>>> ..Tom
>>> Dr. Peter Löwe
>>> <peter.loewe at gmx.de>
>>> Psssst! Schon vom neuen GMX MultiMessenger gehört?
>>> Der kanns mit allen: http://www.gmx.net/de/go/multimessenger
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
