Error: *** glibc detected *** double free or corruption (!prev)
Dominik Schmid dominik.schmid at ILU.CH
Mon Jul 9 07:45:09 EDT 2007
Umberto,
I have done as you suggested. The output reads as follows:
Starting program: /tmp/shp2img -m /in/irr/mb/mb_test.map -l "Zonenplan"
[Thread debugging using libthread_db enabled]
[New Thread -1208117568 (LWP 4843)]
[Mon Jul  9 13:38:33 2007].267262 msPOSTGISLayerOpen called
datastatement: the_geom from zp_au
[Mon Jul  9 13:38:33 2007].288259 msPOSTGISLayerFreeItemInfo called
[Mon Jul  9 13:38:33 2007].288715 msPOSTGISLayerInitItemInfo called
[Mon Jul  9 13:38:33 2007].291176 msPOSTGISLayerWhichShapes called
[Mon Jul  9 13:38:33 2007].291959 msPOSTGISLayerParseData: unique column
= OID, srid='', geom_column_name = the_geom, table_name=zp_au
[Mon Jul  9 13:38:33 2007].293130 query_string_0_6:DECLARE mycursor
BINARY CURSOR FOR SELECT
grundnut::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text
from zp_au WHERE the_geom && setSRID('BOX3D(760644.999999999
249797.999999997,769195.000000001 261197.000000002)'::BOX3D,
find_srid('','zp_au','the_geom') )
*** glibc detected *** double free or corruption (!prev): 0x08f02a40 ***
Program received signal SIGABRT, Aborted.
[Switching to Thread -1208117568 (LWP 4843)]
0x005027a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
As I'm not a programmer but just a simple web developer my debugging
abilities are naturally rather limited.
Dominik
Umberto Nicoletti schrieb:
> Dominik,
> this is getting very hard to do if you don't know a bit about programming.
> If you want to try anyway, run shp2img under gdb with the following
> command:
> #gdb /path/to/shp2img
>> run -m pathtothefile.map -o /tmp/map.png
> When it segfaults issue this command in the gdb shell:
> #backtrace
> and post its output here.
> Umberto
> On 7/9/07, Dominik Schmid <dominik.schmid at ilu.ch> wrote:
>> I have recompiled 4.0.1 with debug enabled. I then replaced the existing
>> shp2img and mapserv.cgi with the newly compiled binaries. Next I ran
>> shp2img with '-all_debug 9' and 'layer_debug 9' for the offending layer
>> (data from zp_au). Since I have no idea what possible debug levels there
>> are or what numbers can be set I have chosen to use a value of 9. Here's
>> the output of shp2img:
>> [Mon Jul  9 12:18:03 2007].176107 msPOSTGISLayerOpen called
>> [Mon Jul  9 12:18:03 2007].185943 msPOSTGISLayerFreeItemInfo called
>> [Mon Jul  9 12:18:03 2007].186621 msPOSTGISLayerInitItemInfo called
>> [Mon Jul  9 12:18:03 2007].189609 msPOSTGISLayerWhichShapes called
>> [Mon Jul  9 12:18:03 2007].190383 msPOSTGISLayerParseData: unique column
>> [Mon Jul  9 12:18:03 2007].192024 query_string_0_6:DECLARE mycursor
>> *** glibc detected *** double free or corruption (!prev): 0x0956da40 ***
>> Since this debug information doesn't help me pinpoint the problem I have
>> to ask back here at the list if this tells anyone here anything.
>> Any help is appreciated.
>> Dominik
>> Umberto Nicoletti wrote:
>> > If you still have the 4.0.1 sources recompile them with enable debug
>> > and run shp2img under gdb. This at least will tell you where the
>> > double free is happening and then you might even be able to fix it.
>> > Umberto
>> > On 7/4/07, Dominik Schmid <dominik.schmid at ilu.ch> wrote:
>> >> Hi
>> >> I have run into this persistent problem and I have already spent hours
>> >> upon
>> >> hours without any result whatsoever. First of all my setup:
>> >> - Centos 4.4
>> >> - apache 2.0.52
>> >> - php 5.1.6
>> >> - postgresql 8.1.8
>> >> - mapserver 4.0.1 (I know, I should update mapserver, but having to
>> >> rebuild
>> >> all the legends in our system and possibly avoid some other side
>> effects
>> >> would be a major headache and have so far kept me from doing this)
>> >> - gdal 1.4.0
>> >> - postgis 1.2.1
>> >> - geos 2.2.3
>> >> - proj 4.5.0
>> >> - glibc 2.3.4-2.25
>> >> The error in the httpd error_log reads as stated in the subject.
>> >> I have added some multipolygon data that I had previously obtained by
>> >> converting it from a shape file using shp2pgsql.
>> >> The odd part about this error is, that I use the same syntax in the
>> >> map file
>> >> as for a working multipolygon layer that I had imported using older
>> >> versions
>> >> of postgis etc. and the older data works just fine.
>> >> I have reimported said working data from the original shape file and
>> >> compared it to the existing data in the working table. the_geom and
>> other
>> >> relevant stuff is identical. And still the newly imported data
>> >> produces this
>> >> error.
>> >> I have checked projection, db access privs and just about
>> everything else
>> >> that crossed my mind as playing a part to no avail.
>> >> So, is this problem a known issue? What else could I try/look into?
>> >> Any advice?
>> >> Thanks
>> >> Dominik
>> Dominik Schmid
>> Dipl. Umweltnaturwissenschafter ETH
>> ilu AG
>> Zentralstrasse 2a
>> CH-8610 Uster
>> Tel: +41 44 / 944 55 56    (Direktwahl)
>> Tel: +41 44 / 944 55 55    (allgemein)
>> Fax: +41 44 / 944 55 66
>> mailto:dominik.schmid at ilu.ch
>> http://www.ilu.ch
Dominik Schmid
ilu AG
Zentralstrasse 2a
CH-8610 Uster
http://www.ilu.ch
