Try to adjust projection parameters via CGI
Edward G. Balas
ebalas at GRNOC.IU.EDU
Tue Jul 10 14:37:33 EDT 2007
Hey Steve,
I finally got back around to verifying that this does work as you
describe.
The only slight trick was getting the correct format for the value
associated
with the map_PROJECTION attribute in the URL.
http://localhost/cgi-bin/mapserv?map=/gnoc/mapserver/
grnoc.map&mapext=-125%2024%20-60%2070&mode=map&map_PROJECTION=proj%
3dortho,lon_0%3d-90,lat_0%3d-10
Thanks for the assist.
On Jun 29, 2007, at 3:13 PM, Steve Lime wrote:
> You can change projections using the map_... syntax. I believe simply
> setting map_projection=new projection string in a url will suffice.
> Steve
>>>> On 6/28/2007 at 1:08 PM, in message
> <4AAF5153-6BED-4288-B381-4EF5F66741BA at grnoc.iu.edu>, "Edward G. Balas"
> <ebalas at GRNOC.IU.EDU> wrote:
>> Hey all,
>> Ive been dorking with mapserver for a while now and cant seem to
>> figure out how to do something which
>> on the surface would seem to be a common task.
>> Within my map, I would like keep lon_0 centered between MINX and MAXX
>> of my extent.
>> The objective is keep the projection centered on what the user is
>> looking at while also allowing the
>> user to change their extent via the CGI interface.
>> I explored using variable substitution but it would appear as if this
>> is not supported in the PROJECTION
>> stanza.
>> Any thoughts on how this might best be accomplished?
>> Edward G. Balas
>> ebalas at grnoc.iu.edu
Edward G. Balas
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070710/19c9ea2e/attachment.html
