qgis - colorrange
Fawcett, David David.Fawcett at STATE.MN.US
Wed Jul 11 15:07:47 EDT 2007
Lucas,
It doesn't look like you have any symbols defined.  I am pretty sure
that with no symbol, you will just get a one pixel symbol.
In your STYLE definition, you will want to add
	     SYMBOL 'circle'
           SIZE 10
For this to work, you will also need a symbol definition for 'circle'
either in a symbols.sym file or in your map file.
The symbol definition would look like this:
Symbol
Name 'circle'
Type ELLIPSE
Filled TRUE
Points
1 1
END
END
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Lucas Beck
Sent: Wednesday, July 11, 2007 11:56 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] qgis - colorrange
Hello,
I am using MapServer version 4.8.3.
I just started to generate a map-file using qgis which generated an
output using "COLORRANGE". However, by trying to embed the map-file into
my web application I can only see very small dots.  All other layers are
OK.
Here the generated layer
LAYER
    NAME 'SUBASINS'
    TYPE POLYGON
    DATA "SUBASINS"
    METADATA
      'wms_title' 'SUBASINS'
    END
    STATUS DEFAULT
    TRANSPARENCY 100
    PROJECTION
    'proj=longlat'
    'ellps=clrk66'
    'datum=NAD27'
    'no_defs'
    END
    CLASS
      STYLE
        COLORRANGE 7 11 250 128 215 255
        DATARANGE 2.000000 14.000000
        RANGEITEM "SUBASINS_"
      END
      STYLE
        OUTLINECOLOR 0 0 50
      END
    END
END
greets
Lucas
