SOS eventTime apparently not working
Kralidis,Tom [Burlington] Tom.Kralidis at EC.GC.CA
Thu Jul 12 09:24:35 EDT 2007
> The following long URL should not return any hits since there
> is no record in our db that falls between the eventTime range
> I specify as part of the URL.
> http://sos-web.tamu.edu/sos-cgi/madis?service=sos&request=GetO
> bservation&ver
> sion=0.1.2&offering=ndbc_44029&responseFormat=text/xml;%20subt
> ype=om/0.14.7&
> observedProperty=http://marinemetadata.org/cf%23air_pressure_a
> t_sea_level&ev
> entTime=<gml:TimePeriod><gml:beginPosition>1990-01-01</gml:beg
> inPosition><gm
> l:endPosition>1990-02-01</gml:endPosition></gml:TimePeriod>
> There is always only 1 row that should be returned -- the
> most recent observation.  As of right now, the time is
> <time>2007-07-12 07:04:00-05</time> which isn't anywhere near
> the TimePeriods defined in the query URL.
> Am I doing something wrong -- that is likely!
>       "sos_timeitem"             "m_date"
>       "sos_offering_timeextent"  "20070530T1800Z"
> It appears that I'm registering the time column properly
> since it does show up in the XML.
> MapServer version 4.99
What does your underlying data connection look like?  Any chance you can
wrap up a test case (.map file and small sample data?)
..Tom
