Help with TIFFTAGs resolutions
Gambin Dejan
Dejan.Gambin at PULA.HR
Fri Jul 13 05:01:32 EDT 2007
I have just one question and that will be all: regarding the screen
resolution - which are the parameters that impact the screen resolution
of my map? If I shiw those images in DWG viewer they are very "sharp"
and look much better than shown on the map, with nearly the same display
dimensions....
Is there a way of modifying it?
regards, dejan
> -----Original Message-----
> From: Frank Warmerdam [mailto:warmerdam at pobox.com]
> Sent: Thursday, July 12, 2007 8:58 PM
> To: Gambin Dejan
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Help with TIFFTAGs resolutions
> Gambin Dejan wrote:
> > Hi,
> > I have a situation that I need to understand, I hope
> someone can help:
> > I have a number of ortophoto images in tif format (with .tfw files).
> > When I show them on my map they should be spatialy
> "connected" but the
> > "empty" space shows between them. Here is the example
> gdalinfo result
> > of the two horizontally adjacent images that should be "connected":
> > Now, I have the similar set of ortophoto images that show correctly
> > and they come from the same source (the National State Geodetic
> > Administration). I have compared them and the difference is
> that this
> > "correct" images have the size of 4500x6000 (exactly 1.6
> bigger than
> > the first one) and their TIFFTAG_XRESOLUTION and
> TIFFTAG_YRESOLUTION
> > are 72 (that is 45x1.6).
> > My question is: who "made the mistake" and what do I have to do to
> > show them correctly (they are shown correctly from a dwg
> file that is
> > referencing them all)? Are the TFW files wrong for this
> resolution? Do
> > I have to change the resolution, image size, or what?
> Dejan,
> It is unlikely that the DWG is utilizing the world files
> (.tfw) at all.
> So if the DWG view is correct it is likely that the world
> files are wrong. If you think the origin's in the world
> files are correct you could try changing the resolution in
> the world files to 0.8 from 0.5 and see if things are properly placed.
> The TIFFTAG_XRESOLUTION and TIFFTAG_YRESOLUTION are not used
> for georeferenced placement or scaling by MapServer or other
> applications.
> BTW, GDAL and MapServer will utilize internal GeoTIFF tags in
> preference to the world files. So if there is wrong internal
> geotiff info it will get used instead of potentially correct
> worldfiles. Keep this in mind if the world files don't seem
> to agree with what gdalinfo is reporting.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo,
> http://osgeo.org
