SUM: Building PHP Mapscript
Bill Thoen
bthoen at GISNET.COM
Tue Jul 17 14:46:32 EDT 2007
I think my version of PHP just came with the distro and I didn't have
its header files. So are you saying that I really should build a new
version of PHP from source or just hope I get lucky? If one has just the
binary PHP is there any other option than rebuilding PHP?
Daniel Morissette wrote:
> Bill Thoen wrote:
>> Thanks everyone for helping get PHP MapScript to compile. I managed
>> to get it to work finally. A word of warning though for anyone else
>> who might need to do this. Unless you plan to rebuild your copy of
>> PHP, make sure you use the same version of PHP source that you are
>> running on your machine. I first tried downloading the latest PHP
>> source, but since that was a few versions newer than what's running
>> on my machine, the resulting php_mapscript.so library wouldn't work
>> (the API versions didn't match). But when I used the same version of
>> PHP source as I have installed on my machine, everything worked fine.
>> In retrospect, I should have expected this, but I seem to have to
>> bang my head against the wall a few times before I realize why I have
>> a headache...
> Well, by downloading and using the PHP source of the same version as
> what is installed on your machine the build worked fine, but there is
> a small possibility that you may still encounter intermittent crashes
> at runtime because the PHP headers are customized to match your build
> options by PHP's configure, and you didn't use the headers that match
> exactly your PHP build options. Options such as the version of REGEX
> or GD used by PHP have an impact on MapScript.
> The only safe way to go is to either point to the PHP source tree that
> has been configured and compiled for your local install of PHP, or
> point to the installed header files (installed by make install or by a
> php-devel package).
> Of course things may still work if you're lucky, but if you encounter
> intermittent crashes you'll know where to start looking.
> Daniel
- Bill Thoen
GISnet - www.gisnet.com
303-786-9961
