PROCESSING "LUT=.... issue
Frank Warmerdam
warmerdam at POBOX.COM
Thu Jul 19 12:39:38 EDT 2007
A.Th.C. Hulst wrote:
> Dear all,
> I have been working on a method to display my freshly computed netCDF data
> through mapserver and are finally there. However, I find one last issue with
> the scaling / processing lut= combination.
> Please see the map on http://mapserver.argoss.nl. The mapserver is svn
> revision 6353. There is a white spot on there that should be red. See the
> relevant map section below:
> LAYER
> NAME "Hs"
> DATA "netCDF:<SNIP>windwave/ww3_output.nc:sign_wave_height"
> PROCESSING "SCALE=0,10"
> PROCESSING "SCALE_BUCKETS=200"
> PROCESSING "BANDS=1,1,1"
> PROCESSING "LUT_1=96:0,157:255,221:255,255:240"
> PROCESSING "LUT_2=29:0,93:255,157:255,221:0,255:0"
> PROCESSING "LUT_3=28:255,93:255,157:0,255:0"
> TYPE RASTER
> STATUS ON
> OFFSITE 0 0 0
> END
> The data in this layer is in [0 13.457]. I want to scale the image to [0 10]
> because more details of lower waves show. What happens is that the RGB values
> in the area that is clipped (eg Hs > 10m) are set to 255, regardless of
> anything in the PROCESSING instruction.
> Am I overlooking something or should I report a bug (or feature ;) )?
Sander,
Do you have a sense where things are going wrong? Is it the scaling or
the LUT application?
I will note that the lut management code assumes that 0 maps to 0 and
255 maps to 255. So I don't think your 255:0 specifications are
going to work.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
