Rotate truetype symbols
Roy Braam
roybraam at B3PARTNERS.NL
Mon Jul 23 08:16:26 EDT 2007
List,
I’ve got a question about rotating (with angle/angleitem) a truetype font symbol.
I’ve created a layer that shows bridges etc. of roads. I’m using a font that has a ‘bridge-symbol’. The direction of the nearest road in angles is stored in a attribute of the bridges-data. It works fine with pixmap symbols. When using truetype font symbols and the angle is 0 it also works fine. But when the angle is getting bigger the symbol deviates more from the real point. The symbol is rotated fine. I think this has to do with the point of rotation of the truetype symbol. In pixmap’s the point of rotation is the center that’s why it works fine. I’m using a truetype font symbol because I want the symbols fully transparent. When the pixmap symbol is rotated it isn’t transparent anymore. I thought this was a good solution….. Can anyone help? My ‘code’ in the mapfile:
LAYER
TYPE POINT
TRANSPARENCY alpha
CLASS
NAME "bridge"
STYLE
#Used in older versions: ANGLEITEM “nearest_road_direction”
ANGLE [nearest_road_direction]
COLOR 0 255 0
SYMBOL "bridge"
SIZE 10
END
STYLE
COLOR 255 0 0
SYMBOL "point1"
SIZE 10
END
END
END
SYMBOL
NAME "bridge"
TYPE TRUETYPE
FONT symbolfont
FILLED TRUE
CHARACTER "D"
ANTIALIAS TRUE
END
SYMBOL
NAME "point1"
TYPE ellipse
points
1 1
end
FILLED true
END
So when the angle is bigger then 0 the symbol ‘point1’ and the center of the symbol ‘bridge’ is not shown on the same point. When angle equals 0 it is.The 'only' thing i want to do is rotate fully transparent symbols...
Tia, Roy Braam
B3partners BV
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070723/3f3afaa2/attachment.html
