WFS encoding problem
Daniel Morissette dmorissette at MAPGEARS.COM
Tue Jul 24 11:31:30 EDT 2007
Milo van der Linden wrote:
> I cannot find information about the gml_encoding parameter anywhere, and
> when I add it to my mapfile, it doesn't influence the encoding that is
> returned.
> This is a link to the mapfile that has "gml_encoding" set to "UTF-8"
> http://82.176.214.209/cgi-bin/mapserv.exe?map=/ms4w/apps/mappingworlds/service/wfs.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=getfeature&TYPENAME=worldcities&maxfeatures=3&OUTPUTFORMAT=gml2
Milo,
The response of your server contains the following header:
    <?xml version='1.0' encoding="UTF-8" ?>
Which leads me to think that setting encoding has worked since the
default encoding returned by MapServer should have been ISO-8859-1 if
you don't explicitly set it to something else.
> Can it be that it should be "wfs_encoding"?
I think that's what the problem was. After checking the source code
again, it seems that WFS GetFeature checks only for wfs_encoding and
ows_encoding but doesn't try gml_encoding.
Sorry for misleading you.  :(
> Should it be placed in the web metadata section of the MAP or of the Layer?
It has to be in the WEB metadata.
Daniel
Daniel Morissette
http://www.mapgears.com/
