Antarctica disappears with Mercator projection
Ei Fujioka
efujioka at DUKE.EDU
Fri Jul 27 17:40:51 EDT 2007
Hello experts,
I'm developing an online mapper where you can change the projection.
http://seamap.env.duke.edu/prod/mapservice/onlinemap/oms_main_v2.phtml
The default projection is the geographic WGS84.
You can change this by switching to [OPTIONS] tab and hit [Projection]
button. In the popup window, if you choose "World Mercator", Antarctica
disappears.
I tried to change latitude values in EXTENT (e.g. -90, -85, etc.) but
didn't make difference.
Any idea why this happens and how to work around?
It's an ESRI's shapefile and Antarctica is projected properly in
Mercator with ArcGIS.
The excerpt from mapfile below.
MAP
NAME "OBIS MAP"
UNITS DD
IMAGETYPE png
EXTENT -180 -83.6236 180 83.6236
PROJECTION
"init=epsg:4326"
END
LAYER
NAME "Continents"
STATUS DEFAULT
DATA "countries"
TYPE POLYGON
TRANSPARENCY 0
PROJECTION
"init=epsg:4326"
END
CLASS
NAME "Countries"
COLOR 204 204 204
OUTLINECOLOR 153 153 153
END
METADATA
"wms_abstract" "Countries"
"TITLE" "Countries"
"wms_title" "Countries"
END
END
END
Thanks,
Ei
Ei Fujioka
Research Associate
Duke University
(919) 613-8021
efujioka at duke.edu
