Authentication
Ruben Pardo
correosig at GMAIL.COM
Mon Jul 30 05:04:26 EDT 2007
Our problem is that we dinamically have to create user group authorization
with different layers, in that case we have to create a mapfile dinamically
with the layers and configure the control access (with apache
authorization?) of the user.
The proxy approach is one of the option that we are considering,
thanks.
2007/7/30, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>:
> Hi,
> Perhaps you could make a separate WMS-service for each user group you
> have? With Mapserver it is easy because you only need to create a new
> mapfile and then control which mapfile the current user can access. This
> should at least prevent fiddling with layer names.
> We are using proxy approach which creates a facede server on a local port
> after successful login and we are rather satisfied with that. System is self
> made but it is in principle close to OWS-proxy by deegree, of Web security
> service by 52nort.org.
> -Jukka Rahkonen-
> ________________________________
> Lähettäjä: UMN MapServer Users List puolesta: Ruben Pardo
> Lähetetty: ma 30.7.2007 10:59
> Vastaanottaja: MAPSERVER-USERS at LISTS.UMN.EDU
> Aihe: Re: [UMN_MAPSERVER-USERS] Authentication
> but if the request is generated in other layer, people can ask with a
> browser to the mapserver changing the name of the layer on the WMS,
> We have a WMS accesible with some layer to everybody and other to
> authenticate users.
> we are thinking on using a remoteWMS like deegree (with WASS) with
> mapserver, a single sign-on or something on apache (mod_auth or similiar).
> but we want to know how people use to implement this issue.
> Thanks.
> 2007/7/30, Gregor Mosheh <gregor at hostgis.com>:
> Ruben Pardo wrote:
> > We want to protect a number of layers to non-authenticate users.
> > I want to ask how people use to protect layers served by
> mapserver? is
> > there any mechanism inside mapserver for this?
> There sure isn't. Authentication has to be done at some other
> layer,
> typically the webserver layer. If Tomcat is generating the
> requests,
> then that'd be the best place to do the authentication.
> Gregor Mosheh / Greg Allensworth
> System Administrator, HostGIS cartographic development & hosting
> services
> http://www.HostGIS.com/
> "Remember that no one cares if you can back up,
> only if you can restore." - AMANDA
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070730/e7b1a840/attachment.html
