Polygon outline width
Gilles Bassière
gilles.bassiere at MAKINA-CORPUS.COM
Mon Jul 30 08:57:42 EDT 2007
Here is my mapfile. The complete Mapfile has 8 other layers but I
removed them in order to make it easy to read, anyway all layers have
the same properties (only the color change).
I also tried to set the OUTLINECOLOR property at the CLASS level and to
use the value -1 0 0 but the outline is still not transparent.
# WGS 84 (epsg:4326)
MAP
NAME "Test"
IMAGETYPE "png"
EXTENT 3.3 50.75 7.25 53.6
IMAGECOLOR 255 255 255
FONTSET "/home/gba/public_html/fonts.txt"
SYMBOLSET "/home/gba/public_html/symbols.sym"
UNITS dd
PROJECTION
"init=epsg:4326"
END
WEB
IMAGEPATH "/home/gba/public_html/img/"
IMAGEURL "/img/"
METADATA
"wms_title" "Road map"
"wms_onlineresource" "http://localhost/~gba/cgi-bin/test.cgi?"
"wms_srs" "epsg:4326"
END
END
# Legend
LEGEND
KEYSIZE 10 5
LABEL
TYPE bitmap
SIZE medium
COLOR 0 0 0
PARTIALS false
END
STATUS on
END
# Scale bar
SCALEBAR
LABEL
COLOR 0 0 0
SIZE tiny
END
STYLE 1
SIZE 50 2
COLOR 0 0 0
UNITS meters
INTERVALS 2
STATUS on
END
OUTPUTFORMAT
NAME "png"
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE "rgba"
EXTENSION "png"
FORMATOPTION "transparent=on"
FORMATOPTION "interlace=on"
END
# Start of LAYER Definitions
# LAYER 9 : water -------------------------------------
LAYER
NAME "water"
GROUP "background"
CONNECTIONTYPE postgis
CONNECTION "host=localhost dbname=test user=test
password=xxxxx port=5432"
DATA "wkb_geometry FROM water"
STATUS on
TYPE polygon
TRANSPARENCY alpha
PROJECTION
"init=epsg:4326"
END
CLASS
STYLE
COLOR 153 179 204
OUTLINECOLOR -1 -1 -1
ANTIALIAS true
END
END
METADATA
"wms_title" "Water bodies"
"wms_srs" "EPSG:4326"
"wms_extent" "3.3 50.75 7.25 53.6"
END
END
END
# test URL (GetMap) :
http://localhost/~gba/cgi-bin/test.cgi?service=wms&version=1.1.1&request=getmap&layers=background&styles=&srs=epsg:4326&width=800&height=600&format=image/png&bbox=3.358400,50.750400,7.227600,53.555000
> Hi Gilles
> How does sour map-file look? OUTLINECOLOR -1 0 0 definitely should work.
> Mit freundlichem Gruss / Best Regards
> Flavio Hendry
> TYDAC Web-Site: http://www.tydac.ch
> TYDAC MapServer: http://www.mapserver.ch
> ############ Mit freundlichen Gruessen / Kind Regards
> ############ mailto:flavio at tydac.ch
> ############ TYDAC AG - http://www.tydac.ch
> #### #### Geographic Information Solutions
> #### #### Luternauweg 12 -- CH-3006 Bern
> ############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
> -----Original Message-----
> From: Gilles Bassière <gilles.bassiere at makina-corpus.com>
> To: Flavio Hendry <flavio at tydac.ch>
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Date: Mon, 30 Jul 2007 11:58:00 +0200
> Subject: Re: [UMN_MAPSERVER-USERS] Polygon outline width
>> Hi Flavio
>> Thanks for your help. Unfortunately, it has no effect on my map. I
>> tried
>> to set this value for OUTLINE in the CLASS element, then in the STYLE
>> element but rivers still appear very thick on my map when the scale
>> in
>> large... Actually, the same map is produced with OUTLINE -1 0 0 or
>> without. =(
>> As explained in the FAQ, I tried to set up a circle symbol but it
>> seems
>> to work only for true lines, not for polygon outlines.
>> Any other idea ?
>> Gilles
>>> Hi Gilles
>>> just set the OUTLINECOLOR to -1 0 0.
>>> Flavio Hendry
>>> From: Gilles Bassière <gilles.bassiere at MAKINA-CORPUS.COM>
>>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>>> Date: Fri, 27 Jul 2007 15:09:22 +0200
>>> Subject: [UMN_MAPSERVER-USERS] Polygon outline width
>>>> Hi there,
>>>> I wonder whether it's possible to have no outline for a polygon.
>>>> My first attempt was to set the WIDTH property of the STYLE
>> element
>>>> to 0
>>>> in my MapFile but I got an error from MapServer, it seems to be an
>>>> invalid value.
>>>> As I might need to display the same data through GeoServer, I
>> decided
>>>> to
>>>> move all style information to a SLD. I wrote the following SLD :
>>>> <?xml version="1.0" encoding="UTF-8"?>
>>>> <StyledLayerDescriptor
>>>> version="1.0.0"
>>>> xmlns="http://www.opengis.net/sld"
>>>> xmlns:gml="http://www.opengis.net/gml"
>>>> xmlns:ogc="http://www.opengis.net/ogc"
>>>> xmlns:xlink="http://www.w3.org/1999/xlink"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>>> xsi:schemaLocation="http://www.opengis.net/sld
>>>> http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd"
>>>> <!-- WATER -->
>>>> <NamedLayer>
>>>> <Name>water</Name>
>>>> <UserStyle>
>>>> <FeatureTypeStyle>
>>>> <Rule>
>>>> <Name>Water bodies</Name>
>>>> <PolygonSymbolizer>
>>>> <Fill>
>>>> <CssParameter
>> name="fill">#99b3cc</CssParameter>
>>>> </Fill>
>>>> <Stroke>
>>>> <CssParameter
>>>> name="stroke">#0000FF</CssParameter>
>>>> <CssParameter
>>>> name="stroke-width">0.0</CssParameter>
>>>> </Stroke>
>>>> </PolygonSymbolizer>
>>>> </Rule>
>>>> </FeatureTypeStyle>
>>>> </UserStyle>
>>>> </NamedLayer>
>>>> </StyledLayerDescriptor>
>>>> My map is rendered without any error but there is still an
>> outline. I
>>>> tried to set opacity to 0.0 but it's not supported by MapServer. I
>>>> can
>>>> set the same color for stroke and fill but having a 1px outline
>> means
>>>> that a very thin river is rendered with, at least, a 2 pixels
>> width
>>>> and
>>>> this is not really nice when viewing the map at higher scales...
>>>> If I remove the Stroke element Mapserver seems to set
>> automatically a
>>>> 1px outline using the fill color.
>>>> Does anyone know a workaround to get rid of polygon outlines ?
>>>> Gilles Bassiere
>>>> MAKINA CORPUS
>>>> 30 rue des Jeuneurs
>>>> FR-75011 PARIS
>>>> http://www.makina-corpus.com
>> Gilles Bassiere
>> MAKINA CORPUS
>> 30 rue des Jeuneurs
>> FR-75011 PARIS
Gilles Bassiere
MAKINA CORPUS
30 rue des Jeuneurs
FR-75011 PARIS
