Strange mapscriptJNI_delete_1layerObj+0xf error killing Tomcat
Rodrigo Del C. Andrade
rodrigo.andrade at DIGITRO.COM.BR
Fri Jun 1 08:59:26 EDT 2007
Thanks a lot for all the replies, folks! I really appreciate it.
I am about to get to work on that, so I will first dl and compile
the svn version and give it a go without any further modifications,
(like delete(), but I gotta say I am kinda of relieved: its a LOT of
stuff to delete). It will be sort of a pain to test it because it is
only crashing on the server, but w/e.
Tamas: thanks too for the tip. Indeed all object creations we have
in the code go with the new obj(parent) constructor. I will see how it
works with the svn version and if it doesn't work I will implement that.
Best regards,
Rodrigo
*Rodrigo Del C. Andrade*
/Programador/
/SIC - SSE - Soluções Segurança Pública/
*DÍGITRO TECNOLOGIA*
*E-mail:* rodrigo.andrade at digitro.com.br
<mailto:rodrigo.andrade at digitro.com.br>
*Fone:* +55 48 3281-7314 / +55 48 3281-7000
*Fax:* +55 48 3281-7299
*Site:* www.digitro.com <http://www.digitro.com>
Umberto Nicoletti wrote:
> I suggest against this practice (no pun intended Benedikt, I sincerely
> appreciate your help).
> I say let's wait until Rodrigo tries out a rfc-24 enabled build,
> frankly I am quite positive rfc-24 will fix his issues.
> Regards,
> Umberto
> On 6/1/07, Benedikt Rothe <umn-ms at hydrotec.de> wrote:
>> Hi
>> Some developers (Umberto, Tamas) work on a solution of this problem.
>> As a workaround I made good experiences with
>> http://lists.umn.edu/cgi-bin/wa?A2=ind0506&L=mapserver-users&P=87500
>> > if we dynamically create mapserver-objects, we allway use code like
>> this:
>> > classObj cO = new classObj(...);
>> > // Do something with cO
>> > //now cO isn't used any more
>> > cO.delete()
>> With "freeing manually" we made the Mapserver inside Tomcat quite
>> stable.
>> Hope, this helps
>> Benedikt
>> UMN MapServer Users List <MAPSERVER-USERS at LISTS.UMN.EDU> schrieb am
>> 31.05.2007 15:13:41:
>> > Hello dear list.
>> > A problem is happening in our production machine which we were
>> > unable to reproduce on our development machines. We have a very
>> > large application almost ready for deployment, in which one of the
>> > modules is written in java mapscript 4.10.1, and the error on the
>> > attached log happened for the first time when we installed the
>> > application on the production server. Whats worse, the GIS module
>> > causing the error brings down Tomcat and the whole application
>> with it.
>> > This is a excerpt from the JVM log:
>> > # An unexpected error has been detected by HotSpot Virtual Machine:
>> > # SIGSEGV (0xb) at pc=0x636ff93b, pid=19162, tid=1759710128
>> > # Java VM: Java HotSpot(TM) Server VM (1.5.0_07-b03 mixed mode)
>> > # Problematic frame:
>> > # C [libmapscript.so+0x3893b]
>> Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1layerObj+0xf
