Error compiling from SVN rev 6166
Tamas Szekeres
szekerest at GMAIL.COM
Fri Jun 1 16:40:15 EDT 2007
This version requires a newer version of the lexer, apparently flex
2.5.31 or so.
This issue might be related to this change.
Best regards,
Tamas
2007/6/1, Rodrigo Del C. Andrade <rodrigo.andrade at digitro.com.br>:
> Hi folks.
> Following the previous discussion about rfc-24, I am trying to
> compile a version from Svn latest revision (6166). All is fine and dandy
> till I try to test the java mapscript lib created.
> Going trough the usual configure and make, mapserver shows no
> problems, same with mapscript/java with make interface and make: no
> problems.
> But 'make test' outputs
> java -classpath ./:examples/:./mapscript.jar -Djava.library.path=.
> WxSTest ../../tests/test.map
> Exception in thread "Thread-2" java.lang.UnknownError: loadLayer():
> Unknown identifier. Parsing error near (MAP):(line 1)
> at edu.umn.gis.mapscript.mapscriptJNI.new_mapObj(Native Method)
> at edu.umn.gis.mapscript.mapObj.<init>(mapObj.java:280)
> at WxSTest_thread.run(WxSTest.java:11)
> Document Length: 9658, expecting somewhere around 10000 or more.
> I am using the same libraries (gd, proj, etc) I had compiled for
> 4.10.1 and other than that the enviroment is the same. I also tried
> issuing a dos2unix to the offending test.map thinking it could be a
> windows carriage return format file, but its not. Swig is version
> 1.3.29, btw.
> Regards,
> Rodrigo
> *Rodrigo Del C. Andrade*
> /Programador/
> /SIC - SSE - Soluções Segurança Pública/
> *DÍGITRO TECNOLOGIA*
> *E-mail:* rodrigo.andrade at digitro.com.br
> <mailto:rodrigo.andrade at digitro.com.br>
> *Fone:* +55 48 3281-7314 / +55 48 3281-7000
> *Fax:* +55 48 3281-7299
> *Site:* www.digitro.com <http://www.digitro.com>
