PHP/MapScript DSO
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Fri Jun 1 17:36:08 EDT 2007
Gregor Mosheh wrote:
>> I know that there are still many sources pointing to the fact that you
>> must
>> run PHP as a CGI for MapScript. I have also seen people talking about
>> running mapscript successfully with PHP as a DSO.
> Yeah, I've been asking off and on about this for the last 2 years. I
> always see one or two "works for me" especially under Windows, and three
> or four "no way" So I dunno... I've not been brave enough to try it on
> our production systems.
> > Can anyone confirm they
>> are running under PHP DSO, and how did you get MapServer/MapScript to
>> compile under DSO? Thanks.
> Mapserver/Mapscript just compiles as you would for the PHP CGI: point to
> the PHP source tree and it builds php_mapscript.so
The definitive answer to this question probably needs to come from DM
Solutions et al, as they are the maintainers of PHP mapscript.
The problem is a nutshell is this:
You can build as a DSO and it will work ... well sort of, but not
really. If you run some hits against it they will work, but the root
problem is that mapserver and hence mapscript has not resolved all the
thread-safety issues yet. It is TONS better than it was a few years ago,
but still has some problems. So when you put your DSO under a little
load and get some multiple requests running it starts to trash the
various threads depending on what you are doing.
There are a lot of things that are currently getting done to improve
things in the code, and it might be getting to the point that if you
test your specific application you might determine that you don't hit
any of those issues. But then again your testing might have just missed
those issues or your next application might fall flat on its face.
Anyway, you see the problem. And as this is a constantly changing
problem with all the code development, you probably need to ask
occasionally what the status is on this. I know I have to ask every 6
months or so to see if it has changed.
-Steve W.
