PHP/MapScript DSO
Armin Burger
armin.burger at GMX.NET
Fri Jun 1 18:11:55 EDT 2007
Timothy,
My experience is that PHP/Mapscript runs well under PHP as DSO when
Apache is a non-threaded version. So either Apache 1.3, or Apache 2 as
prefork version, not the threaded MPM (this is recommended anyway in the
PHP docs, see
http://www.php.net/manual/en/faq.installation.php#faq.installation.apache2).
It seems that on Windows Apache is always threaded, so there I just used
PHP as CGI.
The special options for Mapserver/Mapscript compilation was to add
'--with-php=/usr/local/include/php --with-httpd=/usr/sbin/apache2 '.
Armin
Timothy J Nolte wrote:
> I know that there are still many sources pointing to the fact that you must
> run PHP as a CGI for MapScript. I have also seen people talking about
> running mapscript successfully with PHP as a DSO. Can anyone confirm they
> are running under PHP DSO, and how did you get MapServer/MapScript to
> compile under DSO? Thanks.
> MapServer: 4.10.2
> PHP: 5.1.4
