C# Mapscript Project Deployment using ClickOnce
Jim Bartol
jbartol at MMM.COM
Mon Jun 4 17:06:22 EDT 2007
I have developed a .NET Windows Forms based application that incorporates
Mapserver, and have successfully distributed it to users by using xcopy
deployment. I would now like to distribute this application using
ClickOnce technology. I have been able to successfully publish the
application using the default settings, however it failed when I tried to
deploy to a client machine with the following error message:
ERROR SUMMARY
Below is a summary of the errors, details of these errors are listed
later in the log.
* Activation of C:\ClickOnce Deployments\Rms.application resulted in
exception. Following failure messages were detected:
+ Manifest XML signature is not valid.
+ No signature was present in the subject.
I believe this error could occur if the mapscript_csharp.dll assembly was
not signed when it was created. I have been using the binaries found in
the sample code posted by David Lowther found at
http://mapserver.gis.umn.edu/docs/howto/mapscriptcscompile. Has the
mapscript_csharp.dll in this project been signed? If not, would it be
possible to post a version of this project where the assembly has been
signed.
Has anyone else tried to develop a ClickOnce project with Mapscript?
Thanks for any feedback on this issue,
jb
