MapServer GetFeatureinfo: Geoserver Cascading problems
Rahkonen Jukka
Jukka.Rahkonen at MMMTIKE.FI
Wed Jun 6 06:38:36 EDT 2007
I add here a Mapserver WMS layer definition for a layer that is cascaded from GeoServer WFS. I found it from some old installation and my mapfile was made for MapLab application. I do know that the query button in MapLap-application worked perfectly with this layer, but I fear that I never tested it with WMS GetFeatureInfo. At that time I used MapServer v. 4.6 and GeoServer v. 1.3.
-Jukka Rahkonen-
LAYER
NAME "WFS-parcels"
STATUS OFF
TYPE POLYGON
CONNECTIONTYPE WFS
CONNECTION "http://localhost:8080/geoserver/wfs?"
MAXSCALE 100000
PROJECTION
"init=epsg:2393"
END
CLASS
NAME "baseparcels"
STYLE
OUTLINECOLOR 0 255 0
END
END
METADATA
"wfs_service" "WFS"
"wfs_typename" "GIS_POLYGONS"
"wfs_version" "1.0.0"
"wfs_request_method" "GET"
"wfs_connectiontimeout" "300"
"wfs_maxfeatures" "100000"
"gml_include_items" "all"
END
TEMPLATE "../../../../../../..//ms101/data/query.html"
dump true
# DEBUG TRUE
END
Lähettäjä: UMN MapServer Users List puolesta: Fabio D'Ovidio
Lähetetty: ke 6.6.2007 11:33
Vastaanottaja: MAPSERVER-USERS at LISTS.UMN.EDU
Aihe: Re: [UMN_MAPSERVER-USERS] MapServer GetFeatureinfo: Geoserver Cascading problems
So, which is the problem with my WFS Connection string?
It is:
http://myserver/geoserver/wfs?request=GetFeature&typeName=states
If I write the following GetFeatureinfo:
http://localhost/wwwroot/cgi-
bin/mapserv.exe?map=C:\Inetpub\wwwroot\Prova.map&SERVICE=WMS&bbox=-130,24,-
66,50&request=GetFeatureInfo&layers=sensore&query_layers=sensore&width=550&height
=250&x=170&y=160&version=1.1.1
I have the error:
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException>
msWFSLayerWhichShapes(): WFS connection error. WFS request produced unexpected
output (junk?) for layer Sensore.
</ServiceException>
</ServiceExceptionReport>
so I've found 2 malfunctions:
- First one: I have to write typename and not typeName
- Second: I have specify the version in the request from MapServer even if the string without
version parameter works fine directly on GeoServer.
Any solution ;-) ?
Bye
Fabio D'Ovidio
Web GIS Staff
Planetek Italia s.r.l.
Via Massaua 12, I-70123 Bari
Tel.: +39 080 5343750 Fax: +39 080 5340280
dovidio at planetek.it - http://www.planetek.it
On 5 Jun 2007 at 19:51, Rahkonen Jukka wrote:
> Hi,
> When it comes to the WFS case, one obvious problem is that both MapServer and GeoServer support only version 1.0.0.
> -Jukka Rahkonen-
> -----Original Message-----
> From: UMN MapServer Users List on behalf of Fabio D'Ovidio
> Sent: Tue 5.6.2007 19:05
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] MapServer GetFeatureinfo: Geoserver Cascading problems
> I have a problem in querying my layer from MapServer during a GetFeatureinfo request in a
> cascading configuration with GeoServer, both WMS and WFS (on the same Layer).
> This is my Map file
> __________________________________
> MAP
> NAME "WMS-test"
> STATUS ON
> SIZE 550 250
> SYMBOLSET "C:/Inetpub/wwwroot/symbols/sangroaventino.sym"
> EXTENT -130 24 -66 50
> UNITS METERS
> IMAGECOLOR 255 255 255
> IMAGETYPE PNG
> FONTSET "C:/Inetpub/wwwroot/symbols/fonts.txt"
> WEB
> IMAGEPATH "/ms4w/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> METADATA
> "wms_title" "WMS Demo Server"
> "wms_onlineresource" "http://localhost/wwwroot/cgi-bin/mapserv.exe?"
> "wms_srs" "EPSG:4326"
> END
> END
> PROJECTION
> "init=epsg:42304"
> END
> LAYER # MapServer connects to GeoServer via WMS
> NAME "Sensore"
> TYPE POINT
> STATUS ON
> CONNECTIONTYPE WMS
> CONNECTION "http://myserver/geoserver/wms?service=wms&
> version=1.1.1&bbox=-130,24,66,50&styles=population&
> Format=image/png&request=GetMap&layers=topp:states&
> width=550&height=250&srs=EPSG:4326"
> METADATA
> "wms_title" "Sensore"
> END
> PROJECTION
> "init=epsg:4326"
> END
> TOLERANCE 1000
> CLASS
> COLOR 0 0 0
> SYMBOL 'circle'
> SIZE 15
> END
> END
> END # Map File
> __________________________________________________________________
> This is the GetFeatureInfo to MapServer
> bbox=-130,24,-66,50&request=GetFeatureInfo&
> layers=sensore&query_layers=sensore&width=550&height=250&
> This is the error:
> <ServiceException>
> </ServiceException>
> This is the same Map File with a WFS connection to the same layer described above:
> MAP
> NAME "WMS-test"
> STATUS ON
> SIZE 550 250
> UNITS METERS
> IMAGETYPE PNG
> WEB
> IMAGEURL "/ms_tmp/"
> METADATA
> END
> END
> PROJECTION
> "init=epsg:42304"
> END
> LAYER # MapServer connects to GeoServer via WFS
> NAME "Sensore"
> TYPE POINT
> STATUS ON
> CONNECTIONTYPE WFS
> CONNECTION "http://myserver/geoserver/wfs?
> request=GetFeature&typeName=states"
> METADATA
> END
> PROJECTION
> "init=epsg:4326"
> END
> TOLERANCE 1000
> CLASS
> COLOR 0 0 0
> SYMBOL 'circle'
> SIZE 15
> END
> END
> END # Map File
> This is the GetFeatureInfo (to MapServer)
> This is the error:
> <ServiceException>
> msOGRFileOpen(): OGR error. Open failed for OGR connection
> `/ms4w/tmp/ms_tmp/0354675c1cc6eff953c62e12e7c8aedc.tmp.gml'. File not found or
> unsupported format.
> msBuildWFSLayerPostRequest(): WFS connection error. MapServer supports only WFS
> 1.0.0 or 0.0.14 (please verify the version metadata wfs_version).
> </ServiceException>
> What's wrong?
> Thanks
> Fabio D'Ovidio
> Web GIS Staff
