Google maps & Mapserver projection issue
Jan Hartmann
j.l.h.hartmann at UVA.NL
Wed Jun 6 09:54:03 EDT 2007
Hi Jose,
I think mapext must have two negative and two postive values (you
specify four negative values):
mapext=-7143498.91542+-3665050.56612+7142887.41919+3664442.05663
Does this work?
Jan
joseolcese wrote:
> Jan,
> Thanks a lot for your responses!
> I still have no success getting the right tile with mapscript or even
> mapserv.
> I implemented a code that Ei Fujioka sent me and this is the result:
> I guess I've nailed down the problem to this:
> **** .map with no PROJECTION and latlon coordinates:
> http://127.0.0.1/cgi-bin/mapserv?map=/mapear/map/mapNoProjection.map&mode=map&mapext=-64.171142578125+-31.419288124288343+-64.1656494140625+-31.41460027631321
> This gives me an image with some data printed -> OK
> **** .map with PROJECTION and latlon coordinates:
> http://127.0.0.1/cgi-bin/mapserv?map=/mapear/map/mapProjection.map&mode=map&mapext=-64.171142578125+-31.419288124288343+-64.1656494140625+-31.41460027631321
> This gives me an image with NO data printed -> WRONG
> Only difference between mapNoProjection.map and mapProjection.map is that
> the second one has:
> CONFIG PROJ_LIB '/usr/local/share/proj/'
> PROJECTION
> "init=esri:54004"
> END
> Now, using the code to convert coordinates to mercator meters, I got
> equal to:
> -7143498.91542,-3665050.56612,-7142887.41919,-3664442.05663
> But if I request
> **** .map with PROJECTION and mercator meters coordinates:
> http://127.0.0.1/cgi-bin/mapserv?map=/mapear/map/mapProjection.map&mode=map&mapext=-7143498.91542+-3665050.56612+-7142887.41919+-3664442.05663
> Any ideas??
> Jose
> Jan Hartmann wrote:
>> With Mapscript it's easy:
>> function ll2merc($lon,$lat) {
>> $projIn = ms_newprojectionobj("proj=latlong");
>> $projOut = ms_newprojectionobj("proj=merc");
>> $p = ms_newpointobj();
>> $p->setXY($lon,$lat);
>> $p->project($projIn, $projOut);
>> return($p);
>> If you don't use Mapscript, you have to do the computations in
>> Javascript. There is a project to implement the Proj package in
>> Javascript:
>> http://lists.maptools.org/pipermail/proj/2006-February/002125.html
>> but I have never worked with it
>> Jan
>> Jose Olcese wrote:
>>> Hi Jan,
>>> I really appreciate your help!. It seems that it might be the problem!.
>>> I'll try sending Mercator Coordinates in meters as the mapexp parameter
>>> of mapserv.
>>> Do you have the algorithm for converting it?
>>> Thanks again
>>> Jose
>>> On 6/4/07, *Jan Hartmann* < j.l.h.hartmann at uva.nl
>>> <mailto:j.l.h.hartmann at uva.nl>> wrote:
>>> Hi Jose
>>> Epsg 54004 is the classic Mercator projection. The units it uses are
>>> not
>>> degrees but meters (only at the equator these are real meters). Using
>>> proj I get the following boundary values (note that -180W/-90S and
>>> 180E/90N cannot be represented in a Mercator projection):
>>> proj +init=epsg:54004
>>> -170 -80
>>> -18924313.43 -15496570.74
>>> 170 80
>>> 18924313.43 15496570.74
>>> Hope this helps,
>>> Jan
>>> Dr. J. Hartmann
>>> Department of Geography
>>> University of Amsterdam
>>> joseolcese wrote:
>>> > Hi
>>> > I'm trying to use Google maps & Mapserver with partial success...
>>> > I have a .shp configured in mapserver and I can get a transparent
>>> tile from
>>> > an html page where it load google satellite view and my tiles.
>>> > The problem is that I wasn't using any projection on my .map so
>>> every tile
>>> > was a little distorted.
>>> > I added the epsg:54004 project to the .map but now the tiles are
>>> empty.
>>> > Do you have any idea why this my be happening?
>>> > Thanks
>>> > Jose Olcese
>>> > .map:
>>> > IMAGETYPE PNG
>>> > EXTENT -64.20 -31.41 -64.19 -31.40
>>> > SIZE 256 256
>>> > SHAPEPATH '/ms4w/apps/tutorial/data_jose'
>>> > FONTSET '/ms4w/apps/tutorial/fonts/fonts.list'
>>> > TRANSPARENT ON
>>> > CONFIG PROJ_LIB '/var/www/html/share/proj/'
>>> > PROJECTION
>>> > "init=esri:54004"
>>> > END
>>> > LAYER
>>> > .html:
>>> > tileCountry.getTileUrl=function(xy,zoom)
>>> > var lng = (-180+((xy.x+0.5)*(360/Math.pow(2,zoom))));
>>> // -180
>>> > +180
>>> > var merclat_extent = 360/Math.pow(2,zoom);
>>> > var l = 180 - (( xy.y+0.5) * merclat_extent);
>>> > var e = Math.exp(2 * ( l * Math.PI) /180);
>>> > e = (e - 1)/(e + 1);
>>> > var lat = (Math.atan2(e, Math.sqrt(1 - (e * e))) *180
>>> > Math.PI );
>>> > return
>>> http://127.0.0.1/cgi-bin/mapserv?map=/ms4w/apps/tutorial/htdocs/map_test5.map&mode=map&mapxy=
>>> <http://127.0.0.1/cgi-bin/mapserv?map=/ms4w/apps/tutorial/htdocs/map_test5.map&mode=map&mapxy=>'
>>> > + lng + '+' + lat + '&buffer=' + ((360/Math.pow(2,zoom))/2);
