Image projection question
Stephen Davies
sdc at SDC.COM.AU
Thu Jun 7 02:02:25 EDT 2007
G'day.
I have a georeferenced TIFF aerial photo with the gdalinfo below.
Using a package called Farm Keeper, a shape file was created (by
clicking on the image) containing several polygons defining paddocks.
The shape file was then loaded into PostGIS using shp2pgsql and the
results displayed with MapServer using the original geotiff as the
raster layer.
The result was "almost right" except each of the polygons was displayed
about 20m due north of it's correct position relative to the raster.
The polygon data is stored transformed to SRID 4283. The map projection
is eqc with a central meridian of the centre of the polygons' MBR and
the map extent is the MBR plus approx 100m - slightly smaller than the
raster image extent.
Looking at the Map Server map coordinates, it appears that the polygons
are correctly positioned (the mouse coordinates displayed match the
originals) but the raster has been "moved" (stretched north/south).
Can anybody suggest what has happened?
Cheers and thanks,
Stephen Davies
Driver: GTiff/GeoTIFF
Size is 600, 448
Coordinate System is:
PROJCS["GDA94 / MGA zone 54",
GEOGCS["GDA94",
DATUM["Geocentric_Datum_of_Australia_1994",
SPHEROID["GRS 1980",6378137,298.2572221010042,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6283"]],
PRIMEM["Greenwich",0],
UNIT["degree (supplier to define
representation)",0.01745329251994328],
AUTHORITY["EPSG","4283"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",141],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",10000000],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","28354"]]
Origin = (370139.138699,6182407.307100)
Pixel Size = (2.00000000,-2.00000000)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_DOCUMENTNAME=ER Mapper 7.0
TIFFTAG_IMAGEDESCRIPTION=ER Mapper GeoTiff raster translator V1.0:
Band 1 = Red, Band 2 = Green, Band 3 = Blue
TIFFTAG_SOFTWARE=ER Mapper 7.0
TIFFTAG_XRESOLUTION=0
TIFFTAG_YRESOLUTION=0
Corner Coordinates:
Upper Left ( 370139.139, 6182407.307) (139d35'8.28"E, 34d29'30.38"S)
Lower Left ( 370139.139, 6181511.307) (139d35'7.79"E, 34d29'59.46"S)
Upper Right ( 371339.139, 6182407.307) (139d35'55.32"E, 34d29'30.92"S)
Lower Right ( 371339.139, 6181511.307) (139d35'54.84"E, 34d30'0.00"S)
Center ( 370739.139, 6181959.307) (139d35'31.56"E, 34d29'45.19"S)
Band 1 Block=600x20 Type=Byte, ColorInterp=Red
Band 2 Block=600x20 Type=Byte, ColorInterp=Green
Band 3 Block=600x20 Type=Byte, ColorInterp=Blue
This email is for the person(s) identified above, and is confidential to
the sender and the person(s). No one else is authorised to use or
disseminate this email or its contents.
Stephen Davies Consulting Voice: 08-8177 1595
Adelaide, South Australia. Fax: 08-8177 0133
Computing & Network solutions. Mobile:0403 0405 83
