Problems in testing Java Mapscript
Gaia Trecarichi
gaia.trecarichi at GMAIL.COM
Thu Jun 7 11:04:27 EDT 2007
Hello,
I have some problem in testing Java Mapscript.
I answer some questions posted by Umberto and Rodrigo (thanks for the reply):
- Probably there is a problem with sde91.dll because , using
Dependency Walker to scan mapscript.dll, it is found that sde91.dll is
missing. I cannot understand why mapscript.dll need sde91.dll since
I'm not using arcSDE. In case I need it, how can I download it?
- Yes, I have rebooted Windows after changing SYSTEM path variable
- Yes, I'm sure the path is set correctly in the SYSTEM variable
If someone knows the correct list of the dll needed, please let me know.
Below is reported in plain text the original email I sent some days ago:
Hello,
I'm new in mapserver stuff and I'm trying to use Java Mapscript
without any success.
My environment is:
* Windows XP
* MS4W version 4.10.1.
* JDK 1.6.0_01
* Eclipse
I wanted to test some Java Mapscript functionality with a simple Java
program whose code is the following:
import edu.umn.gis.mapscript.*;
public class ProvaMapscript {
public static void main(String[] args) {
String mappath= new String("C:\\ms4w\\apps\\e-rescue\\" );
mapObj map = new mapObj(mappath.concat(" emergency2.map"));
imageObj image = map.draw();
String image_url = "C:\\ms4w\\tmp\\ms_tmp\\emergency.png";
image.save(image_url, map);
I get the following error:
Exception in thread "main" java.lang.UnsatisfiedLinkError: C:\Program
Files\Java\jre1.6.0_01\bin\mapscript.dll: Can't find dependent
libraries
at java.lang.ClassLoader$NativeLibrary.load(Native Method )
at java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at edu.umn.gis.mapscript.mapscriptJNI.<clinit>(mapscriptJNI.java:23 )
at edu.umn.gis.mapscript.mapObj.<init>( mapObj.java:276)
at ProvaMapscript.main( ProvaMapscript.java:51)
I don't know exactly which libraries mapscript.dll requires but as far
as I could see from some forum the following list of dll's is needed:
bgd.dll
gdal14.dll
geotiff.dll
iconv.dll
kernel32.dll
libcurl.dll
libecwj2.dll
libmap.dll
libmysql.dll
libpq.dll
libproj.dll
libtiff.dll
mapscript.dll
msvcr71.dll
msvcrt.dll
ntdll.dll
pdflib.dll
proj.dll
xerces-c_2_7.dll
zlib1.dll
dwmapi.dll
I have them in the directory "C:\ms4w\Apache\cgi-bin" and this
directory is in the system environment variable PATH.
I don't know exactly which is the problem. I'm thinking to 2 things:
1- As far as I can understand there is a library, namely sde91.dll,
that is needed by libmap.dll. I can't find this library in my
system. Is there anybody who knows where I can download this library?
(but I think I don't need it since I'm not using ESRI's ArcSDE)
2- Is it possible that my Java Mapscript files are not compatible with
my JDK version 1.6.0? I say it because I read in the
README_INSTALL.txt of MS4W the following:
MapScript
Java MapScript: compiled against Java 1.5.07
If anybody could help me in this problem I would be infinitely grateful!!
Thank you in advance,
Gaia
