compiling c# mapscript on F7-x86_64
Tamas Szekeres
szekerest at GMAIL.COM
Thu Jun 7 12:10:37 EDT 2007
Did you compile the mapserver core and mapscript with the same
configuration (by using the same GEOS option for example)?
Best regards,
Tamas
2007/6/7, Mike Leahy <mgleahy at golden.net>:
> Hello List,
> I just finished upgrading one of my 64-bit machines to Fedora 7. I've
> already noticed that binary MapServer packages are installable from the
> repositories. However, it seems these lack the csharp mapscript module,
> which is something I use frequently. So I did my usual routine to
> compile MapServer from source...everything looked okay, until I ran
> 'make test' for the c# mapscript module (see output below). I haven't
> been able to try this on a 32-bit machine, so can only guess that it
> might an issue with the 64-bit environment (though FC6-x86_64 with an
> older version of Mono seemed to work fine). I'm not sure what to make
> of this output from the make test - has anyone seen anything like this
> before, or can anyone make any suggestions?
> Thanks in advance for any help,
> Mike
> [mgleahy at localhost csharp]$ make test
> LC_ALL=C mono ./shpdump.exe ../../tests/point.shp
> Stacktrace:
> at (wrapper managed-to-native) mapscriptPINVOKE.delete_shapeObj
> (System.Runtime.InteropServices.HandleRef) <0x00012>
> (System.Runtime.InteropServices.HandleRef) <0xffffffff>
> at shapeObj.Dispose () <0x00067>
> at shapeObj.Finalize () <0x00018>
> at (wrapper runtime-invoke) System.Object.runtime_invoke_void
> (object,intptr,intptr,intptr) <0xffffffff>
> Native stacktrace:
> mono [0x517025]
> mono [0x4ddf9d]
> /lib64/libpthread.so.0 [0x3fae00dd20]
> /lib64/libc.so.6(cfree+0x3b) [0x3fad073acb]
> ./libmapscript.so(msFreeShape+0x2c) [0x2aaaab573efc]
> ./libmapscript.so(CSharp_delete_shapeObj+0x9) [0x2aaaab53cf69]
> [0x4001f90c]
> Debug info from gdb:
> (no debugging symbols found)
> Using host libthread_db library "/lib64/libthread_db.so.1".
> [Thread debugging using libthread_db enabled]
> [New Thread 46912496280112 (LWP 16759)]
> [New Thread 1075988816 (LWP 16761)]
> [New Thread 1073822032 (LWP 16760)]
> 0x0000003fae00a597 in pthread_cond_timedwait@@GLIBC_2.3.2 ()
> from /lib64/libpthread.so.0
> 3 Thread 1073822032 (LWP 16760) 0x0000003fae00d3d1 in nanosleep ()
> 2 Thread 1075988816 (LWP 16761) 0x0000003fad0c9ad2 in select ()
> from /lib64/libc.so.6
> 1 Thread 46912496280112 (LWP 16759) 0x0000003fae00a597 in
> pthread_cond_timedwait@@GLIBC_2.3.2 () from /lib64/libpthread.so.0
> Thread 3 (Thread 1073822032 (LWP 16760)):
> #0 0x0000003fae00d3d1 in nanosleep () from /lib64/libpthread.so.0
> #1 0x00000000004c1890 in ?? ()
> #2 0x0000003fae0061c5 in start_thread () from /lib64/libpthread.so.0
> #3 0x0000003fad0d062d in clone () from /lib64/libc.so.6
> Thread 2 (Thread 1075988816 (LWP 16761)):
> #0 0x0000003fad0c9ad2 in select () from /lib64/libc.so.6
> #1 0x0000003fb1c5646e in g_spawn_sync () from /lib64/libglib-2.0.so.0
> #2 0x0000003fb1c56838 in g_spawn_command_line_sync ()
> #3 0x00000000005170c7 in ?? ()
> #4 0x00000000004ddf9d in ?? ()
> #5 <signal handler called>
> #6 0x0000003fad073acb in free () from /lib64/libc.so.6
> #7 0x00002aaaab573efc in msFreeShape () from ./libmapscript.so
> #8 0x00002aaaab53cf69 in CSharp_delete_shapeObj () from ./libmapscript.so
> #9 0x000000004001f90c in ?? ()
> #10 0x00002aaaaacf8d20 in ?? ()
> #11 0x0000000000a86770 in ?? ()
> #12 0x0000000000000001 in ?? ()
> #13 0x0000003fae00fa28 in g_str_equal () from /lib64/libpthread.so.0
> #14 0x0000000000a29390 in ?? ()
> #15 0x0000000040223c80 in ?? ()
> #16 0x0000000040223ee0 in ?? ()
> #17 0x000000004001f862 in ?? ()
> #18 0x0000000000a37e68 in ?? ()
> #19 0x0000000040223ee0 in ?? ()
> #20 0x0000000040223e50 in ?? ()
> #21 0x00002aaaaacf8d20 in ?? ()
> #22 0x00002aaaaaad3e60 in ?? ()
> #23 0x0000000000a86770 in ?? ()
> #24 0x00002aaaaacf8d20 in ?? ()
> #25 0x0000000000a86770 in ?? ()
> #26 0x00002aaaaacf8d20 in ?? ()
> #27 0x00000000007ccc08 in ?? ()
> #28 0x000000004001f690 in ?? ()
> #29 0x0000000000a5f0b0 in ?? ()
> #30 0x0000000040223f50 in ?? ()
> #31 0x000000004001f5d8 in ?? ()
> #32 0x00002aaaaacf8d20 in ?? ()
> #33 0x0000000000a86770 in ?? ()
> #34 0x0000000000000001 in ?? ()
> #35 0x0000000000000011 in ?? ()
> #36 0x00002aaaaacf8d20 in ?? ()
> #37 0x00002aaaaacf8d20 in ?? ()
> #38 0x00002aaaaaad3e60 in ?? ()
> #39 0x0000000000a867e0 in ?? ()
> #40 0x0000000000000000 in ?? ()
> Thread 1 (Thread 46912496280112 (LWP 16759)):
> #0 0x0000003fae00a597 in pthread_cond_timedwait@@GLIBC_2.3.2 ()
> #1 0x00000000004bf110 in ?? ()
> #2 0x00000000004c160d in ?? ()
> #3 0x00000000004c5b95 in ?? ()
> #4 0x000000000046ccc6 in mono_domain_finalize ()
> #5 0x00000000004dc754 in ?? ()
> #6 0x0000000000414678 in mono_main ()
> #7 0x0000003fad01daa4 in __libc_start_main () from /lib64/libc.so.6
> #8 0x0000000000413319 in g_str_equal ()
> #9 0x00007fff93e6c348 in ?? ()
> #10 0x0000000000000000 in ?? ()
> Got a SIGSEGV while executing native code. This usually indicates
> a fatal error in the mono runtime or one of the native libraries
> used by your application.
> make: *** [test] Aborted
