Query Map Layer Order
Daniel Morissette dmorissette at MAPGEARS.COM
Thu Jun 7 13:17:18 EDT 2007
John Lhotak wrote:
> In my php script I order my layers using setlayersdrawingorder().  This
> works fine and the layers are drawn in the proper order when using
> draw().  However, when a query is done and the program does drawQuery(),
> the layer order is lost.  Is there way order layers for a query map?
Which version of MapServer are you using? Version 4.8 and older didn't
follow the layer order, but that should be fixed in 4.10 according to
http://trac.osgeo.org/mapserver/changeset/5592
Note that drawQuery has always had a bunch of issues and in the dev
version of MapServer 5.0 msDrawQueryMap() has been modified internally
to call the same code as the regular msDrawMap(), just with a special
flag to request highlighting query results, so all those issues will be
behind us for good.
Daniel
Daniel Morissette
http://www.mapgears.com/
