Lable ANGLE FOLLOW in Chinese
Jackey Cheung
cheung.jackey at GMAIL.COM
Thu Jun 7 21:32:49 EDT 2007
please check this out: http://www3.mapasia.com/jackout/td.rar
in the package, there are:
1. map data of a small portion of Hong Kong, in MapInfo format
2. Chinese font named "mingliu", and the font list.
3. a map file with just road and its label layers.
hope this helps :D
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Friday, June 08, 2007 03:34
Subject: Re: [UMN_MAPSERVER-USERS] Lable ANGLE FOLLOW in Chinese
I still need a good test case- mapfile, font and data. So that would REALLY
help.
Steve
>>> On 6/7/2007 at 10:16 AM, in message <46682158.2050100 at mapgears.com>,
>>> Daniel
Morissette <dmorissette at MAPGEARS.COM> wrote:
> This is a known issue with curved labels. It will hopefully be fixed in
> 5.0. See:
> http://trac.osgeo.org/mapserver/ticket/1921
> Daniel
> Jackey Cheung wrote:
>> Greetings.
>> I've trying to make a map in Chinese
>> http://www3.mapasia.com/jackout/ms.jpg.
>> I've set the ANGLE of all road labels to FOLLOW. It seems some of the
>> label hasn't been broken up properly, as you can see in the image, but
>> most labels are correct. How to fix it?
>> Here's the part of the map file:
>> LABEL
>> ANGLE FOLLOW
>> ENCODING "Big5-HKSCS"
>> COLOR 0 0 0
>> OUTLINECOLOR 255 255 255
>> TYPE TRUETYPE
>> FONT mingliu
>> SIZE 9
>> ANTIALIAS TRUE
>> POSITION AUTO
>> PARTIALS FALSE
>> MINDISTANCE 500
>> BUFFER 5
>> END
