CGI variable "map" is not set
Stephanie Waite
swaite at PWSSC.GEN.AK.US
Fri Jun 8 12:52:58 EDT 2007
Hello, I am trying to work on my first simple map, but I keep getting the
following error:
loadMap(): Web application error. CGI variable "map" is not set.
The URL that I type:
http://localhost/cgi-bin/mapserv.exe?%20map=/ms4w/apps/tutorial/htdocs/example1-1.map&layer=states&mode=map
Here is the Example1-1.map
MAP
IMAGETYPE PNG
EXTENT -97.238976 41.619778 -82.122902 49.385620
SIZE 400 300
SHAPEPATH "/ms4w/apps/tutorial/data"
IMAGECOLOR 255 255 255
LAYER
NAME states
DATA states_ugl
STATUS OFF
TYPE POLYGON
CLASS
NAME "The Upper Great Lakes States"
STYLE
COLOR 232 232 232
OUTLINECOLOR 32 32 32
END
END
END
END
Any help would be appreciated to get me started. Thank you!
