CGI variable "map" is not set
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Fri Jun 8 14:40:11 EDT 2007
Also, since you are using MS4W, you might want to use the "PHP/MapScript
Sample Application" addon package for MS4W for guidance, since it
out-of-the-box sets up a WMS mapfile for you (see your localhost page
after installing).
jeff
Gregor Mosheh wrote:
>> loadMap(): Web application error. CGI variable "map" is not set.
>> The URL that I type:
>> http://localhost/cgi-bin/mapserv.exe?%20map=/ms4w/apps/tutorial/htdocs/example1-1.map&layer=states&mode=map
> Yeah, look at the URL. %20 is a space. Get rid of the space and you
> should be fine.
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
