compiling c# mapscript on F7-x86_64
Mike Leahy
mgleahy at GOLDEN.NET
Sat Jun 9 00:01:20 EDT 2007
Hello again,
I don't know if this helps at all, but I gave the C# dll I built a try
with my application despite the output from the make test...turns out it
actually works. Granted, my application does relatively little at the
moment (it essentially creates a map object with a PostGIS layer, and
draws the image), so this isn't a thorough test, but perhaps there's a
problem with the make test operation instead (at least in my context)?
Regards,
Mike
Tamas Szekeres wrote:
> Mike,
> I haven't managed to reproduce this issue using the SVN trunk on my
> SUSE10 vs MONO 1.2.4 configuration, the make test works fairly well.
> I'll be trying to set up an FC7 system to make similar tests but I
> guess it will take some days to complete.
> Best regards,
> Tamas
> 2007/6/7, Mike Leahy <mgleahy at golden.net>:
>> Tamas,
>> Thanks for the replies. I'm fairly sure what you're suggesting is not
>> the
>> issue in my case. This is a fresh setup, so there's no previous/other
>> versions of mapserver. I tried what you suggested as well, and I got the
>> same output after setting the LD_LIBRARY_PATH to point to my mapserv
>> binaries. Besides that, I've never had to do anything with
>> LD_LIBRARY_PATH
>> before. I'm pretty sure that mapscript_csharp.dll only relies on the
>> libmapscript.so that accompanies it (and through that, all of the other
>> mapserver dependencies). As far as I can tell, libmapscript.so is
>> linked
>> from the current folder for the 'make test' operation. If successful, I
>> normally copy libmapscript.so to /usr/lib64, along with all the other
>> libraries, where it is accessible to any Mono applications that use the
>> csharp DLL.
>> I figure this must be something specific to Fedora 7 and/or
>> Mono-1.2.3. I
>> did try compiling MapServer/MapScript with minimal options to ensure it
>> wasn't some of the additional dependencies I'm using (e.g., GDAL,
>> PostGIS,
>> etc...) and it still gave the same results.
>> Any other recommendations?
>> Regards,
>> Mike
>> On Thu, 7 Jun 2007 20:14:46 +0200, Tamas Szekeres
>> <szekerest at GMAIL.COM> wrote:
>> >You should check whether other version of mapserver is installed or
>> >not. You probably have to set up your mapserver directory in
>> >LD_LIBRARY_PATH when running the tests.
>> >Best regards,
>> >Tamas
>> >> I ran ./configure for MapServer with all desired options, ran make,
>> then
>> >> went into mapscript/csharp and ran make there. Is there something
>> else I
>> >> should have done?
>> >> On Thu, 7 Jun 2007 18:10:37 +0200, Tamas Szekeres
>> wrote:
>> >> >Did you compile the mapserver core and mapscript with the same
>> >> >configuration (by using the same GEOS option for example)?
>> >> >Best regards,
>> >> >Tamas
>> >> >> Hello List,
>> >> >> I just finished upgrading one of my 64-bit machines to Fedora
>> 7. I've
>> >> >> already noticed that binary MapServer packages are installable
>> from the
>> >> >> repositories. However, it seems these lack the csharp mapscript
>> module,
>> >> >> which is something I use frequently. So I did my usual routine to
>> >> >> compile MapServer from source...everything looked okay, until I ran
>> >> >> 'make test' for the c# mapscript module (see output below). I
>> haven't
>> >> >> been able to try this on a 32-bit machine, so can only guess
>> that it
>> >> >> might an issue with the 64-bit environment (though FC6-x86_64
>> with an
>> >> >> older version of Mono seemed to work fine). I'm not sure what
>> to make
>> >> >> of this output from the make test - has anyone seen anything
>> like this
>> >> >> before, or can anyone make any suggestions?
>> >> >> Thanks in advance for any help,
>> >> >> Mike
>> >> >> [mgleahy at localhost csharp]$ make test
>> >> >> LC_ALL=C mono ./shpdump.exe ../../tests/point.shp
>> >> >> Stacktrace:
>> >> >> at (wrapper managed-to-native) mapscriptPINVOKE.delete_shapeObj
>> >> >> (System.Runtime.InteropServices.HandleRef) <0x00012>
>> >> >> (System.Runtime.InteropServices.HandleRef) <0xffffffff>
>> >> >> at shapeObj.Dispose () <0x00067>
>> >> >> at shapeObj.Finalize () <0x00018>
>> >> >> at (wrapper runtime-invoke) System.Object.runtime_invoke_void
>> >> >> (object,intptr,intptr,intptr) <0xffffffff>
>> >> >> Native stacktrace:
>> >> >> mono [0x517025]
>> >> >> mono [0x4ddf9d]
>> >> >> /lib64/libpthread.so.0 [0x3fae00dd20]
>> >> >> /lib64/libc.so.6(cfree+0x3b) [0x3fad073acb]
>> >> >> ./libmapscript.so(msFreeShape+0x2c) [0x2aaaab573efc]
>> >> >> ./libmapscript.so(CSharp_delete_shapeObj+0x9)
>> [0x2aaaab53cf69]
>> >> >> [0x4001f90c]
>> >> >> Debug info from gdb:
>> >> >> (no debugging symbols found)
>> >> >> Using host libthread_db library "/lib64/libthread_db.so.1".
>> >> >> [Thread debugging using libthread_db enabled]
>> >> >> [New Thread 46912496280112 (LWP 16759)]
>> >> >> [New Thread 1075988816 (LWP 16761)]
>> >> >> [New Thread 1073822032 (LWP 16760)]
>> >> >> 0x0000003fae00a597 in pthread_cond_timedwait@@GLIBC_2.3.2 ()
>> >> >> from /lib64/libpthread.so.0
>> >> >> 3 Thread 1073822032 (LWP 16760) 0x0000003fae00d3d1 in
>> nanosleep ()
>> >> >> 2 Thread 1075988816 (LWP 16761) 0x0000003fad0c9ad2 in select ()
>> >> >> from /lib64/libc.so.6
>> >> >> 1 Thread 46912496280112 (LWP 16759) 0x0000003fae00a597 in
>> >> >> pthread_cond_timedwait@@GLIBC_2.3.2 () from /lib64/libpthread.so.0
>> >> >> Thread 3 (Thread 1073822032 (LWP 16760)):
>> >> >> #0 0x0000003fae00d3d1 in nanosleep () from /lib64/libpthread.so.0
>> >> >> #1 0x00000000004c1890 in ?? ()
>> >> >> #2 0x0000003fae0061c5 in start_thread () from
>> >> >> #3 0x0000003fad0d062d in clone () from /lib64/libc.so.6
>> >> >> Thread 2 (Thread 1075988816 (LWP 16761)):
>> >> >> #0 0x0000003fad0c9ad2 in select () from /lib64/libc.so.6
>> >> >> #1 0x0000003fb1c5646e in g_spawn_sync () from
>> /lib64/libglib-2.0.so.0
>> >> >> #2 0x0000003fb1c56838 in g_spawn_command_line_sync ()
>> >> >> from /lib64/libglib-2.0.so.0
>> >> >> #3 0x00000000005170c7 in ?? ()
>> >> >> #4 0x00000000004ddf9d in ?? ()
>> >> >> #5 <signal handler called>
>> >> >> #6 0x0000003fad073acb in free () from /lib64/libc.so.6
>> >> >> #7 0x00002aaaab573efc in msFreeShape () from ./libmapscript.so
>> >> >> #8 0x00002aaaab53cf69 in CSharp_delete_shapeObj () from
>> ./libmapscript.so
>> >> >> #9 0x000000004001f90c in ?? ()
>> >> >> #10 0x00002aaaaacf8d20 in ?? ()
>> >> >> #11 0x0000000000a86770 in ?? ()
>> >> >> #12 0x0000000000000001 in ?? ()
>> >> >> #13 0x0000003fae00fa28 in g_str_equal () from
>> >> >> #14 0x0000000000a29390 in ?? ()
>> >> >> #15 0x0000000040223c80 in ?? ()
>> >> >> #16 0x0000000040223ee0 in ?? ()
>> >> >> #17 0x000000004001f862 in ?? ()
>> >> >> #18 0x0000000000a37e68 in ?? ()
>> >> >> #19 0x0000000040223ee0 in ?? ()
>> >> >> #20 0x0000000040223e50 in ?? ()
>> >> >> #21 0x00002aaaaacf8d20 in ?? ()
>> >> >> #22 0x00002aaaaaad3e60 in ?? ()
>> >> >> #23 0x0000000000a86770 in ?? ()
>> >> >> #24 0x00002aaaaacf8d20 in ?? ()
>> >> >> #25 0x0000000000a86770 in ?? ()
>> >> >> #26 0x00002aaaaacf8d20 in ?? ()
>> >> >> #27 0x00000000007ccc08 in ?? ()
>> >> >> #28 0x000000004001f690 in ?? ()
>> >> >> #29 0x0000000000a5f0b0 in ?? ()
>> >> >> #30 0x0000000040223f50 in ?? ()
>> >> >> #31 0x000000004001f5d8 in ?? ()
>> >> >> #32 0x00002aaaaacf8d20 in ?? ()
>> >> >> #33 0x0000000000a86770 in ?? ()
>> >> >> #34 0x0000000000000001 in ?? ()
>> >> >> #35 0x0000000000000011 in ?? ()
>> >> >> #36 0x00002aaaaacf8d20 in ?? ()
>> >> >> #37 0x00002aaaaacf8d20 in ?? ()
>> >> >> #38 0x00002aaaaaad3e60 in ?? ()
>> >> >> #39 0x0000000000a867e0 in ?? ()
>> >> >> #40 0x0000000000000000 in ?? ()
>> >> >> Thread 1 (Thread 46912496280112 (LWP 16759)):
>> >> >> #0 0x0000003fae00a597 in pthread_cond_timedwait@@GLIBC_2.3.2 ()
>> >> >> #1 0x00000000004bf110 in ?? ()
>> >> >> #2 0x00000000004c160d in ?? ()
>> >> >> #3 0x00000000004c5b95 in ?? ()
>> >> >> #4 0x000000000046ccc6 in mono_domain_finalize ()
>> >> >> #5 0x00000000004dc754 in ?? ()
>> >> >> #6 0x0000000000414678 in mono_main ()
>> >> >> #7 0x0000003fad01daa4 in __libc_start_main () from
>> /lib64/libc.so.6
>> >> >> #8 0x0000000000413319 in g_str_equal ()
>> >> >> #9 0x00007fff93e6c348 in ?? ()
>> >> >> #10 0x0000000000000000 in ?? ()
>> >> >> Got a SIGSEGV while executing native code. This usually indicates
>> >> >> a fatal error in the mono runtime or one of the native libraries
>> >> >> used by your application.
>> >> >> make: *** [test] Aborted
