AGG
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Thu Jun 14 10:02:18 EDT 2007
Peter,
artifacts (in your case pixelation) are expected in jpg images due to
the compression algorithm:
http://en.wikipedia.org/wiki/Compression_artifact
Umberto
On 6/14/07, Peter Bruton <peter.bruton at nrcan.gc.ca> wrote:
> Hello;
> I have been experimenting with AGG in MapServer (CVS April 26/2007) using
> various OUTPUTFORMATs and found the results inconsistent. To experiment
> with various OUTPUTFORMATs (DRIVERs and IMAGEMODEs), a series of mapfiles
> were created that have a single line layer where all features are drawn as
> black lines with a width of one pixel.
> DRIVER GD/GIF and IMAGEMODE PC256
> The lines were rendered as expected. I performed this test as a baseline.
> http://dev.atlas.gc.ca/cgi-bin/mapserv_dev?map=/home/atlas/mapdata/english/pb_gd_gif_pc256.map&mode=map
> DRIVER AGG/PC256 and IMAGEMODE RGBA
> While anti-aliasing was present the pattern of the line was not consistent.
> Sometimes a solid line and other times there were gaps in the line.
> http://dev.atlas.gc.ca/cgi-bin/mapserv_dev?map=/home/atlas/mapdata/english/pb_agg_pc_rgba.map&mode=map
> DRIVER AGG/PNG and IMAGEMODE RGBA
> While anti-aliasing was present, the lines were gray and not black. In
> addition the pattern of the line was not consistent. Sometimes a solid line
> http://dev.atlas.gc.ca/cgi-bin/mapserv_dev?map=/home/atlas/mapdata/english/pb_agg_png_rgba.map&mode=map
> DRIVER AGG/PNG24 and IMAGEMODE RGBA
> http://dev.atlas.gc.ca/cgi-bin/mapserv_dev?map=/home/atlas/mapdata/english/pb_agg_png24_rgba.map&mode=map
> DRIVER AGG/JPG and IMAGEMODE RGBA
> While this produced the best rendering of the line, the background was
> pixelated around the line.
> http://dev.atlas.gc.ca/cgi-bin/mapserv_dev?map=/home/atlas/mapdata/english/pb_agg_jpg_rgba.map&mode=map
> DRIVER AGG/GIF and IMAGEMODE RGBA
> http://dev.atlas.gc.ca/cgi-bin/mapserv_dev?map=/home/atlas/mapdata/english/pb_agg_gif_rgba.map&mode=map
> It is not clear to me why gray and/or lines with inconsistent patterns were
> returned. Are the DRIVER/IMAGEMODE conbinations I am using not compatible
> with one another? Or am I missing something else.
> The symbol definition I am using for the lines in the mapfiles is:
> SYMBOL
> TYPE ELLIPSE
> NAME solidline
> POINTS
> 1 1
> END
> FILLED true
> END
> Any insight to the problems I am having is appreciated.
> Peter Bruton
