Small differences in input and output
Frank Warmerdam
warmerdam at POBOX.COM
Thu Jun 14 11:07:03 EDT 2007
Ed McNierney wrote:
> Frank -
> For MapServer EXTENT purposes Benoit will need to adjust the extents by one
> whole pixel rather than by half a pixel? If there are N pixels horizontally
> measured from the center of the left-hand to the center of the right-hand
> pixel, then there are N+1 pixels measured from the left of the left-hand to
> the right of the right-hand pixel, rather than N+0.5.
> That is, if you adjust all four corners "in" by 0.5 pixel you'll reduce the
> height and width by 1 whole pixel each.
Ed,
If the original file is 100 x 100 (for instance) with gdal reported extents
of (0,0) to (1000,1000) then the mapfile should contain:
EXTENT 5 5 995 995
SIZE 100 100
So the size is determined by the SIZE keyword - not the extents.
Note that mapserver macros like MS_CELLSIZE already account for the fact
that the extents represent a region that is in a sense n-1 pixels wide/long.
eg.
#define MS_CELLSIZE(min,max,d) ((max - min)/(d-1))
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
