Problem with compilation sde support
Ivano Picco
ivano.picco at GMAIL.COM
Wed Jun 20 07:41:10 EDT 2007
You have to install SDE's SDK. you can find it in the SDE DVD.
bye
Ivano
On Wed, 20 Jun 2007 03:35:17 -0500, Martin Koska <martin.koska at SAZP.SK> wrote:
>We have problem with compilation of sde 9.1 support for mapserver 4.10 in
>Debian Linux operation system:
>Sde 9.1 is installed in /opt/sde/sdeexe91.
>We have following files in lib directory:
>developer sdeexe91 # ls lib/
>dbtune_util.spb libicuuc.so.22.0 locator_util.sps sdo_util.spb
>dbtune_util.sps libloceng.so lock_util.spb sdo_util.sps
>layers_util.spb liblocssa.so lock_util.sps sref_util.spb
>layers_util.sps libmtchloc.so logfile_util.spb sref_util.sps
>libedgemt.so libmtchmt.so logfile_util.sps
>svr_config_util.spb
>libgsrvrora9i91.so libpe91.so metadata_util.spb
>svr_config_util.sps
>libicudata.so libsde91.so metadata_util.sps
>version_user_ddl.spb
>libicudata.so.22 libsdeora9isrvr91.so pinfo_util.spb
>version_user_ddl.sps
>libicudata.so.22.0 libsg91.so pinfo_util.sps
>version_util.no_state_seq.spb
>libicui18n.so libtiff.so rastercolumns_util.spb
>version_util.spb
>libicui18n.so.22 libxerces-c.so rastercolumns_util.sps
>version_util.sps
>libicui18n.so.22.0 libxerces-c.so.21 registry_util.spb xml_util.spb
>libicuuc.so libxerces-c.so.21.0 registry_util.sps xml_util.sps
>libicuuc.so.22 locator_util.spb sde_util.sps
>Configuration command is:
>./configure --prefix=/usr --enable-debug --without-tiff --without-pdf
>--with-gd=/usr --with-freetype=/usr --with-zlib=/usr --with-png=/usr
>--with-xpm=/usr --with-jpeg=/usr --with-gdal --with-ogr --with-proj
>--with-eppl --with-postgis --with-wcs --with-wms --with-wmsclient --with-wfs
>--with-wfsclient --with-threads --with-geos --with-sde-version=91
>--with-sde=/opt/sde/sdeexe91
>Error:
>configure: checking whether we should include ESRI SDE support...
>configure: error: "Could not find sdetype.h or libsde91.a/libsde91.so in
>/opt/sde/sdeexe91."
>File libsde91.so is located in /opt/sde/sdeexe91/lib
>Can anybody help to solve the problem?
>What's wrong with this?
>Thank you.
>Martin Koska
>martin.koska at sazp.sk
