ROSA pan
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Wed Jun 20 08:39:14 EDT 2007
Chameleon has its own mailing list for questions like this (join at
http://lists.maptools.org/mailman/listinfo/chameleon).
Eduardo Zenaide wrote:
> other question: i'm trying to use chameleon just to understand the
> widgets. i've already put the files and create the conf file. happens
> that all pages give this error:
> *Warning*:
> fopen(c:/tmp/ms_tmp/9b39e07d9c2fa23a768d6ef41c196df3_mlt.inc.php) [
> function.fopen <http://localhost:82/chameleon/samples/function.fopen>]:
> failed to open stream: No such file or directory in
> *C:\ms4w\apps\chameleon\htdocs\common\mlt\mlt.php* on line *743
> ** C:\ms4w\apps\chameleon\htdocs\common\mlt\mlt.php* is correct. what
> could it be?
> thanks in advance
> 2007/6/19, Eduardo Zenaide <ezenaide at gmail.com <mailto:ezenaide at gmail.com>>:
> can i use it without using chameleon adding it to other application?
> 2007/6/19, Jeff McKenna <jmckenna at dmsolutions.ca
> <mailto:jmckenna at dmsolutions.ca>>:
> You might have better luck using something like Chameleon which
> has a
> pan widget out-of-the-box.
> jeff
> > hi,
> > how can i use a nice pan with ROSA applet?
> > like, instead of that 'recenter' tool, could i be able to pan?
> > Eduardo Zenaide
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
