mapscript with java
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Wed Jun 20 09:33:47 EDT 2007
Which version of ms4w?
Umberto
On 6/20/07, Victor Herrero Cazurro <la_barrenadora at hotmail.com> wrote:
> Hello Umberto,
> this is the information that appears in the file "hs_err_pid5260.log".
> the version of mapserver that I use is the one of "MS4W". it is why it comes
> precompiled and when not compiling I do not have it access to the
> configuration.
> # An unexpected error has been detected by HotSpot Virtual Machine:
> # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0492fadc, pid=5260,
> tid=5836
> # Java VM: Java HotSpot(TM) Client VM (1.5.0_11-b03 mixed mode, sharing)
> # Problematic frame:
> # C [gdal14.dll+0x18fadc]
> --------------- T H R E A D ---------------
> Current thread (0x02d48788): JavaThread "Thread-41" daemon
> [_thread_in_native, id=5836]
> siginfo: ExceptionCode=0xc0000005, reading address 0x00000004
> Registers:
> EAX=0x00000000, EBX=0x055d0c48, ECX=0x00000000, EDX=0x7c38b1c0
> ESP=0x053dd8bc, EBP=0x056a6dd0, ESI=0x051f7580, EDI=0x00000001
> EIP=0x0492fadc, EFLAGS=0x00010206
> Top of Stack: (sp=0x053dd8bc)
> 0x053dd8bc: 04a81740 04a81704 05218ff0 055d0c48
> 0x053dd8cc: 056a6dd0 0467aefc 05622b78 7c3505dc
> 0x053dd8dc: 0454cb50 055d0c48 05622b78 00000001
> 0x053dd8ec: 05213de0 056a6dd0 0454d115 056a6dd0
> 0x053dd8fc: 05622b78 05218fb8 056a6dd0 04560ec5
> 0x053dd90c: 056a6dd0 00000010 0457188c 056a6dd0
> 0x053dd91c: 0566f008 0520e050 0521f358 ffffffff
> 0x053dd92c: 0521f358 05218fb8 0521f4d8 056a6dd0
> Instructions: (pc=0x0492fadc)
> 0x0492facc: 17 a8 04 68 40 17 a8 04 e8 a1 18 e7 ff 8b 4e 0c
> 0x0492fadc: 8b 14 b9 52 e8 ac 3d e7 ff 8b 4e 08 8b 46 0c 8b
> Stack: [0x053a0000,0x053e0000), sp=0x053dd8bc, free space=246k
> Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native
> code)
> Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
> j edu.umn.gis.mapscript.mapscriptJNI.mapObj_OWSDispatch(JJ)I+0
> j
> edu.umn.gis.mapscript.mapObj.OWSDispatch(Ledu/umn/gis/mapscript/OWSRequest;)I+8
> j es.nomenclator.struts.action.MapServerAction$WxSTest_thread.run()V+66
> v ~StubRoutines::call_stub
> --------------- P R O C E S S ---------------
> Java Threads: ( => current thread )
> 0x02d5c5d8 JavaThread "Thread-42" daemon [_thread_in_native, id=5340]
> =>0x02d48788 JavaThread "Thread-41" daemon [_thread_in_native, id=5836]
> 0x00a82ea0 JavaThread "TP-Monitor" daemon [_thread_blocked, id=6040]
> 0x00a82518 JavaThread "TP-Processor4" daemon [_thread_in_native, id=6004]
> 0x02d97998 JavaThread "TP-Processor3" daemon [_thread_blocked, id=6240]
> 0x02d97010 JavaThread "TP-Processor2" daemon [_thread_blocked, id=6260]
> 0x00aab5d8 JavaThread "TP-Processor1" daemon [_thread_blocked, id=5888]
> 0x00aa98c0 JavaThread "http-8080-Monitor" [_thread_blocked, id=5948]
> 0x03252ab8 JavaThread "http-8080-Processor25" daemon [_thread_blocked,
> id=8136]
> 0x03251ff0 JavaThread "http-8080-Processor24" daemon [_thread_blocked,
> id=6032]
> 0x03251580 JavaThread "http-8080-Processor23" daemon [_thread_blocked,
> id=6016]
> 0x03250b10 JavaThread "http-8080-Processor22" daemon [_thread_blocked,
> id=6068]
> 0x03250130 JavaThread "http-8080-Processor21" daemon [_thread_blocked,
> id=5636]
> 0x031f7680 JavaThread "http-8080-Processor20" daemon [_thread_blocked,
> id=6052]
> 0x031f6c10 JavaThread "http-8080-Processor19" daemon [_thread_in_native,
> id=6036]
> 0x031f61a0 JavaThread "http-8080-Processor18" daemon [_thread_blocked,
> id=6012]
> 0x0315a220 JavaThread "http-8080-Processor17" daemon [_thread_blocked,
> id=5984]
> 0x03159808 JavaThread "http-8080-Processor16" daemon [_thread_blocked,
> id=6028]
> 0x031542a8 JavaThread "http-8080-Processor15" daemon [_thread_blocked,
> id=7832]
> 0x03161408 JavaThread "http-8080-Processor14" daemon [_thread_blocked,
> id=5696]
> 0x02ef0dd0 JavaThread "http-8080-Processor13" daemon [_thread_blocked,
> id=5016]
> 0x02ef0c48 JavaThread "http-8080-Processor12" daemon [_thread_blocked,
> id=5996]
> 0x03166110 JavaThread "http-8080-Processor11" daemon [_thread_blocked,
> id=5992]
> 0x0324b9d0 JavaThread "http-8080-Processor10" daemon [_thread_blocked,
> id=6000]
> 0x031673e0 JavaThread "http-8080-Processor9" daemon [_thread_blocked,
> id=5600]
> 0x0322dd18 JavaThread "http-8080-Processor8" daemon [_thread_blocked,
> id=6084]
> 0x03242808 JavaThread "http-8080-Processor7" daemon [_thread_blocked,
> id=6112]
> 0x031ef7f0 JavaThread "http-8080-Processor6" daemon [_thread_blocked,
> id=5476]
> 0x031babd0 JavaThread "http-8080-Processor5" daemon [_thread_blocked,
> id=6140]
> 0x02f86d80 JavaThread "http-8080-Processor4" daemon [_thread_blocked,
> id=5700]
> 0x031d0da0 JavaThread "http-8080-Processor3" daemon [_thread_blocked,
> id=6124]
> 0x031526e0 JavaThread "http-8080-Processor2" daemon [_thread_blocked,
> id=6220]
> 0x031235c0 JavaThread "http-8080-Processor1" daemon [_thread_blocked,
> id=6152]
> 0x031c0c88 JavaThread
> "ContainerBackgroundProcessor[StandardEngine[Catalina]]" daemon
> [_thread_blocked, id=1860]
> 0x031c1bc8 JavaThread "MySQL Statement Cancellation Timer" daemon
> [_thread_blocked, id=6168]
> 0x02d36d10 JavaThread "Timer-0" daemon [_thread_blocked, id=5288]
> 0x00a72148 JavaThread "Low Memory Detector" daemon [_thread_blocked,
> id=5536]
> 0x00a70dc8 JavaThread "CompilerThread0" daemon [_thread_blocked, id=4412]
> 0x00a700c0 JavaThread "Signal Dispatcher" daemon [_thread_blocked,
> id=5348]
> 0x00a6af70 JavaThread "Finalizer" daemon [_thread_blocked, id=6180]
> 0x00a6ab00 JavaThread "Reference Handler" daemon [_thread_blocked,
> id=4328]
> 0x003a64f8 JavaThread "main" [_thread_in_native, id=5036]
> Other Threads:
> 0x00a681d0 VMThread [id=6268]
> 0x00a6fda0 WatcherThread [id=5272]
> VM state:not at safepoint (normal execution)
> VM Mutex/Monitor currently owned by a thread: None
> Heap
> def new generation total 768K, used 190K [0x22ad0000, 0x22ba0000,
> 0x22fb0000)
> eden space 704K, 27% used [0x22ad0000, 0x22affb18, 0x22b80000)
> from space 64K, 0% used [0x22b80000, 0x22b80000, 0x22b90000)
> to space 64K, 0% used [0x22b90000, 0x22b90000, 0x22ba0000)
> tenured generation total 9124K, used 5473K [0x22fb0000, 0x23899000,
> 0x26ad0000)
> the space 9124K, 59% used [0x22fb0000, 0x23508420, 0x23508600,
> 0x23899000)
> compacting perm gen total 8960K, used 8816K [0x26ad0000, 0x27390000,
> 0x2aad0000)
> the space 8960K, 98% used [0x26ad0000, 0x2736c120, 0x2736c200,
> 0x27390000)
> ro space 8192K, 67% used [0x2aad0000, 0x2b02f150, 0x2b02f200,
> 0x2b2d0000)
> rw space 12288K, 47% used [0x2b2d0000, 0x2b879750, 0x2b879800,
> 0x2bed0000)
> Dynamic libraries:
> 0x00400000 - 0x0040d000 C:\Archivos de
> programa\Java\jdk1.5.0_11\bin\javaw.exe
> 0x7c910000 - 0x7c9c6000 C:\WINDOWS\system32\ntdll.dll
> 0x7c800000 - 0x7c901000 C:\WINDOWS\system32\kernel32.dll
> 0x77da0000 - 0x77e4c000 C:\WINDOWS\system32\ADVAPI32.dll
> 0x77e50000 - 0x77ee1000 C:\WINDOWS\system32\RPCRT4.dll
> 0x77d10000 - 0x77da0000 C:\WINDOWS\system32\USER32.dll
> 0x77ef0000 - 0x77f36000 C:\WINDOWS\system32\GDI32.dll
> 0x77be0000 - 0x77c38000 C:\WINDOWS\system32\MSVCRT.dll
> 0x6d740000 - 0x6d8dd000 C:\Archivos de
> programa\Java\jdk1.5.0_11\jre\bin\client\jvm.dll
> 0x76b00000 - 0x76b2e000 C:\WINDOWS\system32\WINMM.dll
> 0x6bd00000 - 0x6bd0d000 C:\WINDOWS\system32\SYNCOR11.DLL
> 0x6d300000 - 0x6d308000 C:\Archivos de
> programa\Java\jdk1.5.0_11\jre\bin\hpi.dll
> 0x76bb0000 - 0x76bbb000 C:\WINDOWS\system32\PSAPI.DLL
> 0x6d710000 - 0x6d71c000 C:\Archivos de
> programa\Java\jdk1.5.0_11\jre\bin\verify.dll
> 0x6d380000 - 0x6d39d000 C:\Archivos de
> programa\Java\jdk1.5.0_11\jre\bin\java.dll
> 0x6d730000 - 0x6d73f000 C:\Archivos de
> programa\Java\jdk1.5.0_11\jre\bin\zip.dll
> 0x6d540000 - 0x6d553000 C:\Archivos de
> programa\Java\jdk1.5.0_11\jre\bin\net.dll
> 0x71a30000 - 0x71a47000 C:\WINDOWS\system32\WS2_32.dll
> 0x71a20000 - 0x71a28000 C:\WINDOWS\system32\WS2HELP.dll
> 0x20b00000 - 0x20b45000 C:\WINDOWS\system32\imon.dll
> 0x71a50000 - 0x71a5a000 C:\WINDOWS\system32\WSOCK32.dll
> 0x20c00000 - 0x20c0d000 C:\Archivos de programa\Eset\pr_imon.dll
> 0x77660000 - 0x77681000 C:\WINDOWS\system32\NTMARTA.DLL
> 0x76f20000 - 0x76f4d000 C:\WINDOWS\system32\WLDAP32.dll
> 0x774b0000 - 0x775ec000 C:\WINDOWS\system32\ole32.dll
> 0x71b90000 - 0x71ba3000 C:\WINDOWS\system32\SAMLIB.dll
> 0x719d0000 - 0x71a10000 C:\WINDOWS\system32\mswsock.dll
> 0x66740000 - 0x66799000 C:\WINDOWS\system32\hnetcfg.dll
> 0x71a10000 - 0x71a18000 C:\WINDOWS\System32\wshtcpip.dll
> 0x10000000 - 0x10095000 C:\ms4w\Apache\cgi-bin\mapscript\java\mapscript.dll
> 0x04510000 - 0x0473f000 C:\ms4w\Apache\cgi-bin\libmap.dll
> 0x04740000 - 0x04752000 C:\ms4w\Apache\cgi-bin\zlib1.dll
> 0x04760000 - 0x04796000 C:\ms4w\Apache\cgi-bin\proj.dll
> 0x7c340000 - 0x7c396000 C:\WINDOWS\system32\MSVCR71.dll
> 0x047a0000 - 0x04ba2000 C:\ms4w\tools\gdal-ogr\gdal14.dll
> 0x745e0000 - 0x7461d000 C:\WINDOWS\system32\ODBC32.dll
> 0x58c30000 - 0x58cc7000 C:\WINDOWS\system32\COMCTL32.dll
> 0x7c9d0000 - 0x7d1ee000 C:\WINDOWS\system32\SHELL32.dll
> 0x77f40000 - 0x77fb6000 C:\WINDOWS\system32\SHLWAPI.dll
> 0x76360000 - 0x763aa000 C:\WINDOWS\system32\comdlg32.dll
> 0x7c3a0000 - 0x7c41b000 C:\WINDOWS\system32\MSVCP71.dll
> 0x770f0000 - 0x7717c000 C:\WINDOWS\system32\OLEAUT32.dll
> 0x04bb0000 - 0x04bdb000 C:\ms4w\Apache\cgi-bin\libcurl.dll
> 0x04be0000 - 0x04cee000 C:\ms4w\Apache\cgi-bin\LIBEAY32.dll
> 0x04cf0000 - 0x04d21000 C:\ms4w\Apache\cgi-bin\SSLEAY32.dll
> 0x55300000 - 0x5542a000 C:\ms4w\Apache\cgi-bin\pdflib.dll
> 0x04d30000 - 0x04d4d000 C:\ms4w\Apache\cgi-bin\LIBPQ.dll
> 0x76740000 - 0x76749000 C:\WINDOWS\system32\SHFOLDER.dll
> 0x04d50000 - 0x04e64000 C:\ms4w\Apache\cgi-bin\iconv.dll
> 0x04e70000 - 0x04e7d000 C:\ms4w\Apache\cgi-bin\libfcgi.dll
> 0x04e80000 - 0x04f6c000 C:\ms4w\Apache\cgi-bin\geos_c.dll
> 0x04f70000 - 0x0505a000 C:\ms4w\Apache\cgi-bin\libxml2.dll
> 0x773a0000 - 0x774a2000
> C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.2180_x-ww_a84f1ff9\comctl32.dll
> 0x20000000 - 0x20018000 C:\WINDOWS\system32\odbcint.dll
> 0x612d0000 - 0x612eb000 C:\WINDOWS\system32\odbccp32.dll
> 0x77bd0000 - 0x77bd8000 C:\WINDOWS\system32\VERSION.dll
> 0x76ee0000 - 0x76f07000 C:\WINDOWS\system32\DNSAPI.dll
> 0x76f70000 - 0x76f78000 C:\WINDOWS\System32\winrnr.dll
> 0x76f80000 - 0x76f86000 C:\WINDOWS\system32\rasadhlp.dll
> 0x00000000 - 0x00000000
> VM Arguments:
> jvm_args: -Dcatalina.home=C:\Tomcat 5 -Dcatalina.base=C:\Tomcat 5
> -Djava.endorsed.dirs=C:\Tomcat 5/common/endorsed -Djava.io.tmpdir=C:\Tomcat
> 5\temp -Djava.library.path=C:\Archivos de
> programa\Java\jdk1.5.0_11\bin;C:\Tomcat
> 5\bin;C:/ms4w/Apache/cgi-bin/mapscript/java;C:/ms4w/Apache/cgi-bin
> -Dsun.io.useCanonCaches=false
> java_command: org.apache.catalina.startup.Bootstrap start
> Launcher Type: SUN_STANDARD
> Environment Variables:
> PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\ms4w\tools\gdal-ogr;C:\ms4w\Apache\cgi-bin;C:\ms4w\Apache\cgi-bin\mapscript\java
> USERNAME=victorherrero
> OS=Windows_NT
> PROCESSOR_IDENTIFIER=x86 Family 15 Model 2 Stepping 9, GenuineIntel
> --------------- S Y S T E M ---------------
> OS: Windows XP Build 2600 Service Pack 2
> CPU:total 1 (cores per cpu 1, threads per core 1) family 15 model 2 stepping
> 9, cmov, cx8, fxsr, mmx, sse, sse2
> Memory: 4k page, physical 1539616k(618212k free), swap 3484984k(2705696k
> free)
> vm_info: Java HotSpot(TM) Client VM (1.5.0_11-b03) for windows-x86, built on
> Dec 15 2006 01:16:12 by "java_re" with MS VC++ 6.0
> >From: "Umberto Nicoletti" <umberto.nicoletti at gmail.com>
> >To: "Victor Herrero Cazurro" <la_barrenadora at hotmail.com>
> >CC: MAPSERVER-USERS at lists.umn.edu
> >Subject: Re: [UMN_MAPSERVER-USERS] mapscript with java
> >Date: Wed, 20 Jun 2007 11:11:28 +0200
> >Please read this first:
> >http://mapserver.gis.umn.edu/docs/howto/javamapscript
> >especially last section. We can't help you without that info.
> >Umberto
> >>Hello!
> >>I'm a java Developer and i use mapscript library to make a consult "WFS
> >>getfeature" to "MAPSERVER" in Apache, i prove the java example in this url
> >>"http://mapserver.gis.umn.edu/docs/howto/wxs_mapscript/#java-example"
> >>I change the parameter
> >>mapObj map = new mapObj(mapName);
> >>map.setMetaData( "ows_onlineresource", "http://dummy.org/" );
> >>req.setParameter( "SERVICE", "WMS" );
> >>req.setParameter( "VERSION", "1.1.0" );
> >>req.setParameter( "REQUEST", "GetCapabilities" );
> >>For
> >>mapObj map = new
> >>mapObj("c:\\ms4w\\Apache\\htdocs\\mapserver\\app\\app.map");
> >>map.setMetaData( "ows_onlineresource", "http://localhost/cgi-bin/mapserv"
> >>OWSRequest req = new OWSRequest();
> >>req.setParameter( "SERVICE", "WFS" );
> >>req.setParameter( "VERSION", "1.0.0" );
> >>req.setParameter( "REQUEST", "getfeature" );
> >>req.setParameter( "TYPENAME", "layer_name" );
> >>And obtain this error
> >># EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x036b68c3, pid=7444,
> >>tid=7552
> >># C [gdal14.dll+0x168c3]
> >># An error report file with more information is saved as
> >>hs_err_pid5260.log
> >># If you would like to submit a bug report, please visit:
> >># http://java.sun.com/webapps/bugreport/crash.jsp
> >>somebody can help me ????
> >>Thanks in advance!
> >>_________________________________________________________________
> >>Horóscopo, tarot, numerología... Escucha lo que te dicen los astros.
> >>http://astrocentro.msn.es/
> Acepta el reto MSN Premium: Correos más divertidos con fotos y textos
> increíbles en MSN Premium. Descárgalo y pruébalo 2 meses gratis.
> http://join.msn.com?XAPID=1697&DI=1055&HL=Footer_mailsenviados_correosmasdivertidos
