How to use queryByShape
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Wed Jun 20 11:29:47 EDT 2007
There is no lame question... ;-)
Things to check:
- first, is the layer being queried queryable? That is, does it have a TEMPLATE set?
- are there any possible projection issues? Search shape in a different coordinate system than the points...
- does the search shape have a bounding box? Depending on how you built it there's a chance it may not and the bbox is used to initially select candidate shapes before the more expensive intersection computations are done. There is a method to rebuild the bbox if necessary (name escapes me though).
Steve
>>> On 6/20/2007 at 9:35 AM, in message
<c52191e30706200735v278e8355s8d41fe2f47496b0b at mail.gmail.com>, Nico Alberti
<nico at LANGHIRANO.IT> wrote:
> Hi everybody. I am quite new to php_mapscript, so excuse me if the
> question is lame.
> I am trying to select which points of a shape are inside a particular
> area, (a shape from a polygon shapefile), so I do something like
> this, after having instantiated the objects:
> $map->prepareQuery();
> $ret=$layerPoints->queryByShape($ShapeAreaObject);
> However, even if I am sure that some points fall within the area of
> $ShapeAreaObject, nothing is selected. It seems I am missing
> something, but after having read the documentation and the list, I did
> not find any clue. Using the php_ogr extension, the points that fall
> within the area (or better its envelope) are correctly selected, but,
> again, it is certainly my fault, as it's the first time I use this
> library.
> Any help will be greatly appreciated, thank you in afvance
