Newbie With Some Questions
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Thu Jun 21 07:51:56 EDT 2007
Paul Yelk wrote:
> 1. Installing the MS4W package - will it change any of my Windows XP Pro
> registry settings? (I had previously installed the trial version of
> ArcView and when I removed it using a very good uninstaller program
> called "Your Uninstaller", it left behind a lot of ArcView entries in
> the registry! At one time I removed 1,800+plus entires, but still see
> some more left behind! Don't want that mess again in case I need to
> remove it!)
If you use the '.zip' file it won't modify the registry. If you use the
'.exe' installer it will modify the registry.
> 2. Do I need to be concerned about writing all these configuration
> files? Or will MS4W work in it's default configuration without a lot of
> modifications to the configuration files?
The MS4W download page has links to several 'applications packaged for
MS4W' that are pre-configured to work in that environment.
> 3. In the MS4W readme file, it mentions running MS4W as a service. I do
> not want to do this as this will initially be installed on my home
> computer for testing purposes. Once testing is complete, I will upload
> it to a web host for online use.
Then follow the instructions in the "NOTE for Win95,98,ME users" section
to start Apache manually.
> In the MS4W readme file, it mentions that for Windows 95/98/ME users,
> it can not be run as a service. They have to manually start it each time
> they want to use it and then just close the DOS box to stop MS4W from
> running. Can I also do this for Windows XP Pro?
Yes.
> 4. If, after evaluation, I find this program to meet our needs, what do
> I upload to a web host? And how do it upload it to a web host so that it
> is in the "root" folder of some drive?
It always depends on the operating system of your web host. If it is
windows nothing is different in setup from your local machine. Unix is
a different story.
Note: MS4W questions like this should be sent to the MS4W mailing list
(join at http://lists.maptools.org/mailman/listinfo/ms4w-users).
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
