ROSA pan
Piero Cavalieri
piero.cavalieri at GMAIL.COM
Fri Jun 22 05:12:50 EDT 2007
This one should use it:
http://www2.tetonwyo.org/mapserver/
If you have some hours to write a bit of code, I suggest to try it. These 2
links are usefull:
http://www.greenwoodmap.com/mapserver/Ottawa-workshop/presentation/outline.html
http://mapserver.gis.umn.edu/docs/howto/jbox
JBox itself doesn't have a toolbar, but it's not too much difficult to take
one (for example the Mapsurfer one) and to use it with the JBox.
Cheers
Piero
2007/6/22, LITTLE Nelson <nelson.little at tenix.com>:
> Are there any examples on the web that use jBox? I would like to see some
> before trying it.
> *From:* UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On
> Behalf Of *Piero Cavalieri
> *Sent:* Wednesday, 20 June 2007 5:14 PM
> *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Subject:* Re: [UMN_MAPSERVER-USERS] ROSA pan
> If u want to use a java applet, there's also jBox (which has both
> "recenter" and "pan"). If u want the equivalent, using javascript, there's
> dBox, but in the "old" version it has a recenter tool (not pan). In the the
> new one, I don't know.
> Piero
> 2007/6/19, Eduardo Zenaide <ezenaide at gmail.com>:
> hi,
> how can i use a nice pan with ROSA applet?
> like, instead of that 'recenter' tool, could i be able to pan?
> Eduardo Zenaide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070622/3f00bdda/attachment.html
