working with database in UTF-8
Jackey Cheung
cheung.jackey at GMAIL.COM
Mon Jun 25 04:49:42 EDT 2007
I was suspecting that the TTF would be the cause, but I'm not sure which
font come with Windows is UTF-8 font, or where to get one.
Pls advise. thx.
----- Original Message -----
From: "Stephen Woodbridge" <woodbri at SWOODBRIDGE.COM>
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Saturday, June 23, 2007 02:45
Subject: Re: [UMN_MAPSERVER-USERS] working with database in UTF-8
> Jackey,
> I suspect that the font file is not utf8 or the data is already mangled
> before it gets to mapserver. The mapserver stuff works fine for me with
> utf-8 data in shapefiles as long as I set the ENCODING 'utf8' in the
> LABEL. A bigger issue might be:
> What is the encoding on the source data?
> what is the encoding on the database?
> was the data loded correct with respect to the encoding?
> if you do a select * from table in mysql does the data display correctly?
> if you slect the records with ogrinfo? to a file or you monitor do they
> show corectly?
> There are a WHOLE lot oof steps where things could have broken before it
> gets to mapserver. You need to validate the data is still good as it comes
> into mapserver.
> -Steve W.
> Steve Lime wrote:
>> Hmmm... All the encoding parameter does is tell MapServer to convert from
>> the supplied encoding to
>> unicode so I don't think it has any effect. If you already have
>> unicode/utf-8 strings then this should
>> just work assuming your font has the right characters.
>> Does a simple shapefile work?
>> Steve
>>>>> On 6/22/2007 at 2:56 AM, in message
>> <bfb704a40706220056t20220029n82b4ec43aa5e3854 at mail.gmail.com>, Jackey
>> Cheung
>> <cheung.jackey at GMAIL.COM> wrote:
>>> Greetings!
>>> I'm trying to setup a mapserver that supports multiple languages with
>>> MySQL.
>>> The database uses UTF-8, while the map server use a select statement to
>>> retrieve records. The layer goes as:
>>> LAYER
>>> NAME sr
>>> STATUS OFF
>>> TYPE POINT
>>> CONNECTIONTYPE OGR
>>> CONNECTION "<OGRVRTDataSource>
>>> <OGRVRTLayer name='sr'>
>>> <SrcDataSource>MYSQL:MapSQL,user=root,password=123456,host=localhost,port=3306
>>> ,tables=POI</SrcDataSource>
>>> <SrcSQL>SELECT `Name`,
>>> geom
>>> FROM `POI` WHERE `ID` = %o%</SrcSQL>
>>> <GeometryType>wkbPoint</GeometryType>
>>> </OGRVRTLayer>
>>> </OGRVRTDataSource>"
>>> DATA "sr"
>>> UNITS METERS
>>> MAXFEATURES 1
>>> LABELITEM "Name"
>>> CLASS
>>> SYMBOL "point"
>>> MINSIZE 10
>>> COLOR 250 0 0
>>> OUTLINECOLOR 0 128 0
>>> LABEL
>>> ENCODING "utf-8"
>>> COLOR 255 0 0
>>> OUTLINECOLOR 255 255 255
>>> TYPE TRUETYPE
>>> FONT arial
>>> SIZE 8
>>> ANTIALIAS TRUE
>>> POSITION UC
>>> PARTIALS FALSE
>>> BUFFER 5
>>> FORCE TRUE
>>> END
>>> END
>>> END
>>> All Chinese characters are shown as question marks (?) on the map, no
>>> mater
>>> using arial or Chinese fonts.
>>> Any advise?
